Question about Sharp Viewcam VL-A10U Camcorder
Sharp view cam vl a10
My view cam will not charge when i plug it in the charge light goes red but after a while just flashes red does this mean i need a replacement battery
My view cam is blury when you try to play any movies on it.
Posted on Aug 11, 2008
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
The red light flashes when its charging
Had this problem myself and found that the voltage of the battery was too low for the camera to charge (2.8 volt,s)
I manually charged the battery up past 3 volt,s then put it back in the camera and plugged it in--the light did stop flashing and did finaly turn green.
Or just get an external charger online for cheep.
Oct 24, 2009 | Sharp Viewcam VL-AH50U Hi-8 Analog...
Ihave a view cam made by sharp and the model #vl-ah160 and it does not hold its charge even wih new batteries.i had drop it and i was wondering if this can cause it fo not holding a charge
if it still works ..I dont think this should have cause any problems ....I guess the power issues came from poor quality of the accumulators or better from a not that great formating of them when they were brand new....another cause may be the age ...after all even in mobile phones , those rechargeable ones have a limited life time ...and his is the way they behave .....I mean they begin to last less and less.. a solution might be new ones...or even try to never let them inside the camera even when the power is off...cause all cameras empty them batteries when they aren;t even on ...
Sep 10, 2009 | Sharp Viewcam VL-AH160U Hi-8 Analog...
I own a sharp VL-A10 viewcam
Negetive external posetive internal.
Dec 03, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp viewcam VL-A10
According to the manual the red X means the heads may be dirty or worn out. I was looking at the manual for the VL-A110U camcorder as it seems like the closest thing but the red X is pretty universal. Your older tapes are probably fine. Sometimes a small piece of tape gets stuck in the tape head and is not easily dislodged. I would tyr using the cleaning tape 10 seconds at a time maybe 3 times, waiting a couple of minutes between cleaning as the heads get hot. If that doesn't do it you will probably need to take it to a reputable repair shop to see if they can do something.
Manual for the VL-A110U is available here.
http://www.sharpusa.com/products/TypeManuals/0,1083,47,00.html
Sep 23, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp VL A10 audio video cable
Is the both ends of the cable color red, yellow and white.
You can buy it in any electronics center or store. just tell RCA Cable.
melnavz
Aug 24, 2008 | Sharp Viewcam VL-A10U Camcorder
Battery charge
I'd start there. Usually the flashing red indicates that the charging function is not working. A defective battery can cause this.
Dan
Jun 10, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp vl-nz50
i need the software and the driver for my video camera
Nov 25, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Camcorder Error
for a quick fix I usually override it by slightly opening the tape when its being loaded, i think its a sensor issue. my cams been rendered useless because of this stupid error, I cant even sell it now because it only works 10% of the time and that's usually when im just checking out the cam, only when I need it the most does it screw up on me
Jun 06, 2006 | Sharp Viewcam VL-A10U Camcorder
Sharp Viewcam VL-A10U Camcorder Logo
372 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
