Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
There is a flashing warning light on our Delonghi coffee maker indicating that the descale program should be run. However I'm having problems getting the descaler program to start. Following the instructions, I switch the machine on, wait for the green lights to stop flashing, then hold in the rinse and descaling button for 5 seconds. When the light stablises ( on constantly), I switch the steamer on.... and wait. Nothing further occurs. I've left it for an hour. Nothing. Switching the machine off and back on again returns it to the flashing scale alarm state. Any tips on how I can get the descaler to run appreciated. Thank you.
Mostly it is just a very unreliable product. I am on my 3rd replacement after only 14 months.
Posted on May 24, 2011
Red light keeps flashing all the times
Witch red light?
Could be that the red light telling you to descale the unit is flashing.
if so then you have to descale the unit...see manual
Oct 05, 2016 | DeLonghi Espresso And Cappuccino Maker -...
Descale eam3400 delonghi magnifica machine
Hi, you need to select descale procedure from menu options and then add descale solution usually 100-125ml to 1l of water to your tank. Also you should find this how to do in instruction manual.
Jun 28, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
Flashing coffee and descale
Identical problem, descale light doesn't extinguish despite descaling correctly. Coffee continues to be made as normal though ! Any solution ideas please ?
Mar 04, 2013 | DeLonghi Coffee Makers & Espresso Machines
The descaling light stays on even though I have gone thru the process of descaling.
You are not completing the descale program. See below.
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over
time it is normal for the tubing inside the machine to fill with lime scale.
When the light starts flashing( chap. 12-point 5), it is time to descale
the machine.
NOTE: when the light switches on, the coffee maker can still be used to
prepare coffee.
Proceed as follows:
• Empty the tank and pour in the contents of one bottle (125 ml) of
DURGOL descaler plus one liter of water. For subsequent descaling
operations, descaling solution can be purchased from authorised
technical service centres.
NB: Make sure splashes of descaler do not fall onto surfaces sensitive
to acid such as marble, limestone and glaze.
• place a container with a minimum capacity of 1.5 litres under
the milk frother (Fig. 3);
• turn the machine on by pressing the button (Fig. 4).
• wait for the green and indicator lights to come on steady.
• press and hold the button for at least 5 seconds (Fig.14). The
light inside the button switches on (chap. 11 - point 8) to indicate
the start of the descaling program (the and lights remain
off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn anticlockwise (Fig.5). The
descaling solution will come out of the milk frother and start to
fill the container underneath.
• the descaling program automatically performs a series of deliveries
and pauses, so as to remove the lime scale deposits from
inside the coffee maker.
Fig.32
The two red buttons
have opened
out CORRECTLY
The two red buttons
have not
opened out
CORRECT INCORRECT
33
OPERATING INSTRUCTIONS
• after around 30 minutes, when the light comes on (chap. 12 - GB
point 1), turn the steam knob half a turn clockwise (Fig.6) until it
stops.
The machine must be rinsed so as to eliminate the residues of descaling
solution from inside the machine. Proceed as follows:
• remove the water tank, rinse it and fill it with clean water.
• reposition the tank.
• empty the collection container (located under the milk frother) that is
full of liquid, and then replace it under the milk frother.
• turn the steam knob half a turn anticlockwise (Fig. 5). Hot water will
come out of the milk frother and fill the container underneath.
• when the tank is empty, the light goes off and the light
comes on (chap. 12 - point 1).
• turn the steam knob all the way clockwise (Fig. 6) and fill the water
tank with clean water again.
• the program of descaling is hour terminated and the machine is
ready per do again the coffee.
NOTE: if the descaling procedure is stopped before completion, the
alarm (chap. 12 - point 5) is not deactivated and the procedure
must be started again form the beginning.
IMPORTANT: THE GUARANTEE IS NOT VALID IF THE ABOVE DESCALING OPERATION
IS NOT PERFORMED REGULARLY.
Sep 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Why doesn't my descaler light ever go off from flashing?
Perform the full descaling program as described in the manual to reset the descaling counter.
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
How do you descale my Delonghi Magnifica?
10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
Jul 14, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Cant remember how to de scale
Instructions per De'Longhi:
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing, it is time to descale the machine.
Proceed as follows:
cappuccino frother;
• turn the machine on by pressing the button.
• press and hold the button for at least 5 seconds. The decalcification warning light will illuminate to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn counter-clockwise. The
• after around 30 minutes, when the light comes on, turn the steam knob half a turn clockwise until it stops.
• turn the steam knob half a turn counter-clockwise. Hot water will come out of the milk frother and fill the container underneath.
• when the tank is empty, the indicator light goes off and another light (looks like a pitcher pouring water) comes on.
• turn the steam knob all the way clockwise and fill the water
NOTE: if the descaling procedure is interrupted before completion, the alarm is not deactivated and the procedure
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE WARRANTY.
You can download the entire pdf manual from the De'Longhi website: http://www.delonghiusa.com/index.php?texts&pid=10&catid=1
Helpful tips:
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water or use abrasive cleaning products/scouring materials on any part of your espresso machine.
Jun 24, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
I need to decalcify my delonghi 4500
Descaling is another word for decalcification - I would consult the user manual for your exact model, because these directions are actually for the EAM3400, so there might be minor variations:
When the appliance displays the message:
DESCALE
You should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE NO
• Press and the appliance displays the message:
DESCALE YES
• Press the button to start the descale program.
• Empty the tank and pour in the contents of one bottle (4.2 fl. oz.) of DURGOL descaler plus 34 oz. of
service centers.
and glaze.
• Place a plastic or glass container with a minimum capacity of 50 oz under the hot water spout (Fig. 3);
• Turn the steam knob half a turn counterclockwise (fig.3). The descaling solution will run out of the cappuccino
• The descale program automatically performs a series of run offs and pauses to remove lime scale deposits
• After about 30 minutes, the appliance displays:
DESCALING COMPLETED TURN KNOB
• Turn the steam knob a half turn clockwise as far as it will go (fig. 4).
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• Remove the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the collection container (under the cappuccino frother) full of liquid and then put it back under the
cappuccino frother.
• Turn the steam knob a half turn counterclockwise (fig. 3).
18
Hot water is run off from the cappuccino frother into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETED TURN KNOB
• Turn the steam knob clockwise as far as it will go (fig. 4) and refill the water tank with clean water.
• The descale program is now complete and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the program must be started again from the beginning.
Mar 22, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Mar 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
2,302 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
