Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
I have a Hitachi 43FDX10B that has got too much red in the picture..is it the bulb or something else?..the picture has soft edges and all the red and purple tones are overwhelming
  • Hitachi Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
I have a Hitachi 43FDX10B that has got too much - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Why do i have double picture on right side of tv
It seems that the colour convergence chips went out. You need to buy the chips and get it fixed to get your problem solved.
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Hitachi FDX Series 43FDX10B 43" Rear...
How do you get the High Def. Picture?
Make sure you are using the red green and blue cables and not just the video
yellow ,red and white Inputs
the component cables will give you almost as good as the hdmi cable
The debate over monster cables and other is an on going discussion.
I personally have found little or no difference in the 30 dollar cables vs the 200 dollar cables
As long as you are running the component in on the tv you should have a very nice picture
Jan 11, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Is my Hitachi Tv model 43FDX10B HD ready?
Probably but this hitachi has no reall HD just simulated, called D3VirtualHD by hitachi. Should work, you can always return the blu-ray if it's not what you expected or ask a good salesman if it's worth, you might try it in store...
cheers
Dec 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Tv sceen
use medical alchool and cotton any thing soft that wont scratc the screen!
plz do rate this post
Dec 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Red on/off indicator light never turns off
I had that same problem intermittently for about six months. Now I have no picture, just three small vertical lines in the center of the screen. One red, one green and one blue. Can anyone help? I know its outdated but I'd hate to throw the set in the dumpster if it just needs a little mainentance.
Jul 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
SEEING DOUBLE IMAGE
replace both convergence ICs they are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi
if you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Apr 28, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Red huge is out of line and tried to adjust on the tv.The tv is a Hitachi.We just had another dish service put in. Thanks Janice
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 31, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Picture disfigured
If you have tried doing a convergence setup and still have the problem you probably have a bad convergence IC. I usually replace both of them while I'm in there. They're not that expensive and it saves trouble later. If you are good with a soldering iron and know TV safety it is not that hard to do. Good luck.
Jun 26, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
