Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
We turned on the oven to **** and we saw smoke coming out. Then we put the self clean and it got really hot. is that bad.? what can we do to fix this problem. and the door is lock.
  • Whirlpool Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Oct 11, 2010
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
Microwave is smoking when I use it as a convection oven
It seems to be self cleaning... burning all the oils that coats the inside from microwaving food that wasn't covered. Clean the oven well and to remove bad smells put lemon juice in a bowl and microwave.
http://www.wikihow.com/Remove-Odors-from-a-Microwave
Nov 13, 2013 | KitchenAid Architect Series KEMC308KSS...
How do you clean a self-cleaning gas oven?
If it's one with pyrolytic oven coatings then you empty the oven and turn the oven to maximum for about three hours.
The linings will get hot enough to burn deposits to a light ash residue which you can then wipe off with a damp cloth when the oven has cooled down.
Some modern ovens have a self-cleaning setting on one of the controls. All it does is to automate the process and to lock the oven door until the cycle has completed.
Note that you will smell the fumes as the oven self-cleans and they can set off any smoke alarms you have. Also, if the oven is really filthy and thickly caked in grease then the pyrolysis will not be fully effective. Note that oven shelves and other metal fittings and also door glass are not pyrolytic and any deposits will get baked on, so clean those separately first. Really stubborn deposits will come off using a caustic-soda based cleaners, but you must wear suitable protective gloves, glasses and clothing and exercise extreme care when using them as caustic soda burns are far, far, worse than acid burns.
Jul 09, 2011 | Whirlpool SB160PEE Gas Single Oven
I have a new Frigedaire self cleaning oven. Before I got to read the manual my daughter baked a cake which dripped onto the oven floor and began to smoke. To catch more drips I put a pice of tinfoil on...
Greetings,
remove as much tin foil that is possible...use something like hot water and mild detergent to loosen up the baked on cake residue...this should come up ok with alittle elbow grease...then run your self clean cycle...All will be ok....Bruce Denton
Jan 20, 2011 | Frigidaire Ovens
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
How to clean after an oven fire
Cheryl,
If you can't scrape the plastic off then heating it up to soften it is about your only choice short of putting it back in self clean with a fan in the nearest window blowing outside to evacuate the smoke. Depending how bad it is and how cold it is where you live, you might even try freezing if off. Get it as cold as possible and see if the cold makes it easier to chip off. As far as the element, I suggest turning the oven on and letting it smoke and burn clean. Shouldn't be a very long process since the element will get hot so fast the plastic will drip off right away.
Hope that helps... Brian
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Smoking Kenmore
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
Oct 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE oven self cleaning
try fix found here http://www.fixya.com/howto/h155060-dreaded_f7_error
worked for me
Jun 30, 2008 | GE Profile JTP18 Electric Single Oven
Oven cleaning bosch oven
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Feb 10, 2008 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
77 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
