Question about Nostalgia Electrics ICM-507 Old Fashioned Soft Serve Ice Cream Maker
How do I get a replacement freezer drum for my Nostalgia electric Ice Cream Machine? Mine was kept in the freezer and split open and oozed some sort of goo out.
We get ice cream, but it is not firm . . more of a soup how to adjust
There are two types of machine. Cheap ones where you have to pre-freeze an insert and chill to mix to almost frozen. Then the more expensive ones that have a compressor in them and are actually an electric freezer with a paddle.
If you have the cheap sort, then nothing you can do apart from following the instructions and chilling and freezing everything well.
With the freezer type, you need a refrigeration engineer as it probably needs more refrigerant gas.
Apr 24, 2016 | Ice Cream Makers
How do I repair nostalgia ice maker?
Don't know if this will help: http://nostalgiaelectrics.com/product/ric100-retro-series-50s-style-automatic-ice-maker/
Jul 19, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Broken Gear
This might be helpful.
http://home.hiwaay.net/~karthur/Freezer/White%20Mountain%20Motor%20Repair.html
Jan 02, 2014 | White Mountain F69206X 6 Quart Ice Cream...
I need the instructions for nostalgia ice cream maker and the model number is ICMP400BLUE.
Hello, I have located the manual that you requested for your nostalgia ice cream maker ICMP400BLUE. You can retrieve the manual by either clicking on this link or copy and pasteing the link to your browser. If you have any issues in reading this manual or retrieving it from the link that I have provided please message me back and if also you have any questions at all either on this appliance or any other you can also message me with any of those as well. Please also remember when our chat has fully concluded to rate how this service has performed in helping you to locate your manual. By doing this it allows me to continue helping others in similar situations for others in the future. Click this link http://www.nostalgiaelectrics.com/manuals/ICMP400BLUE.pdf
Thank you again I await any further questions and Have a Happy New Year,
Rick
Dec 31, 2011 | Nostalgia Electrics ICMP-400BLUE Ice Cream...
Does the dasher move on the ice cream maker or just the canister?
The dasher rotates, driven by the motor. The canister isn't supposed to move, but sometimes will depending on how thick the ice cream mixture gets. Presumably, if the ice cream were to freeze hard enough, the dasher would find it harder and harder to turn, until eventually the entire canister, with the dasher embedded in the ice cream, would start to rotate in the ice.
Mar 04, 2011 | Nostalgia Electrics ICMP-400BLUE Ice Cream...
Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
Welcome to FixYa
An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
Read Following ...
  • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
  • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
  • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
  • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
  • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
OR click here
Just Check this Link too
Thanks for Contacting FixYa...
Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
Need replacement parts
Unfortunately, Nostalgia Electrics has stopped (AGAIN!) production of the ICM-517 and ICM 562 Soft Serve Ice Cream Makers. And the company customer service is a "bear" to get a call back from. You could go to the Helman Group, LTD website or the Nostalgia Electrics website and click on customer service and type in your request, but don't expect a quick answer. And there is an 800 # to call also, but you will only get the voice mail and leave a message. No live person, just a call back, if you're really really good and really lucky. It's a shame they have so much trouble with these, they seem to do well with the Popcorn machines, cotton candy, and drink machines, hot dogger, ect. You'd think they could debug this one too. Kindest regards, Joe.
Feb 09, 2008 | Nostalgia Electrics ICM-507 Old Fashioned...
Manual for nostalgics ice-cream maker
I found the manual able to be downloaded on multiple sites. Go to Google, type in the words old fashioned ice cream maker, and in the returns you will find links to web addresses that have these manuals available for downloading using Adobe. The original manuals in both English and Spanish. I didn't save the webaddresses, but I can assure you that they are there on Google. Don't type in Nostalgic Electrics Old Fashioned Ice Cream Server, just old fashioned ice cream server, and then go to the web address, it's the one that states they have the manuals for all ice cream makers, and type in the ICM-507 product designation or just click the available picture of the ICM-507. I will try and recover that web address and post it here. Found it! Here it is: www.pickyourown.org/icecreammakermanuals.htm I can assure you it is there! if you want the whole enchalada: www.pickyourown.org/icecream/Nostalgia%20%old%fashioned%20%soft%20serve%20ice%20cream%20maker%20manual%20ICM-562.pdf. And thats the real "skinny" for this model folks! Whew, you'll have carpal tunnell time you put all that in there. Kindest regards, Joe R. Downs Jr.
Dec 30, 2007 | Nostalgia Electrics ICM-507 Old Fashioned...
Nostalgia Electrics ICM-507 Old Fashioned Soft Serve Ice Cream Maker Logo
41 people viewed this question
Top Nostalgia Electrics Ice Cream Makers Experts
Tom Chichester
Bill Boyd
Are you a Nostalgia Electrics Ice Cream Maker Expert? Answer questions, earn points and help others
