A couple of things you can check:
* Is the little magnet still attached to the pedal crank (probably on the left side)?
* Is the magnet 'reader' still attached to the frame (again, probably on the left)?
* Does the magnet 'reader' need batteries? Do they need changing?
* Does the reader still line up with the magnet? Close enough to 'read'?
Rgds,
Scott
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
try using heavy duty star washer instead of the flat one.take the side foot panel off you will see the bolt that you would tighten for tension,to the w/belt this mite help in it not lossening up.
the Q4000 only funs 400 max and thats at 4ohms bridged 2x200 if you need high powered amps i would look at soundstream or MTX and you would need atleast 1 secondary battery cause to max a amp out you need to have constant 14.4 volts going to power the amp.
The FX500 is 4 x 75 watts clean and 1 x 500 watts RMS @2 ohm mono. What subs are you running and what are the ohms per voice coil. Single or dual voice coil. By what you said (not getting hot) sounds to me like the load istoo much. Let me know.
