Question about HP PSC 750 All-In-One InkJet Printer
How do I get the machine to scan? Can it be sent to my computer?
  • 8,197 Answers
On the link below it will tell you how to scan. Just click on the Use the scan features on the left side of the link.
http://h10032.www1.hp.com/ctg/Manual/bpu02250.pdf
Good Luck and please accept the answer
Posted on Oct 10, 2010
"Connection with Computer Failed" When I Try to Scan
If the primitive (as you call it) Windows Scan program is working then there is no problem with the machine. It can connect to the computer.
I suspect that the other (non primitive) scanning software is not configured correctly. It may be using a wrong driver. You may have installed some other device that is able to scan (such as a program that capture screens from calculators) and it has been set as default driver. Check the configuration of your scanning software.
Jan 23, 2014 | Lexmark OfficeEdge Pro5500 4-in-1 Inkjet...
I am not able to scan a ducument andemail it from my computer
Make sure the Lexmark OCR scan software is installed on your computer. The scan software is available only in the install disc that came with your printer. Were you able to scan to your computer before? If yes, it could be a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
Apr 29, 2011 | Lexmark X5470 All-In-One InkJet Printer
.I want to know step
Open this link (click here), you'll find all the scanning instructions/tutorials related to your printer.
You'll need to select the tutorials depending on how you would like to scan using your printer. Since there are several ways, scanning with the hp solution center software, scanning from paint, scanning from photoshop, etc..etc.. etc.. I can't make it specific.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 06, 2010 | Computers & Internet
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
How do I use my Ricoh Aficio 1035 for scanning and can it be sent to my computer?
Yes you can use it for scanning to your computer. You must have the scan option installed to do this. Does the left side of your operations panel have a button labeled scanner? If so and you push it, it should give you the scanner operation screen. If all this is true then all you need to do is have someone setup the machine on your netrwork for scanning.
If you do not have this button or if you do and you push it says this option not installed then you will need a network print/scan kit. You can find these on Ebay for less than $200. Installation and configuration will cost you another $100.00 to $150.00
Oct 22, 2009 | Ricoh Aficio 1035 Copier
Scanning
this is a long process, if the machine is on the network, you can access the on board ram by typinjg in the address of the machine into your web browser. From there you need to enter the admin area, top left of page. Enter: admin, press the tab key twice and you should be in. From there you need to set up an address for the copier to scan to: this is done through the address book and you need to select SMB and then enter in the path to the PC
Aug 13, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Scanning
NotAnExpert,
I believe that you will be able to change that setting by using the web interface for the Konica Minolta.
Open your browser and enter the following:
http://xxx.xxx.xxx.xxx
xxx.xxx.xxx.xxx represents the IP address of your Printer.
This should open your configuration interface. In the center of the page there should be a series of tabs: System, Job, File, Print, Scan.
Choose Scan and toward the bottom of your page you should see the destination folder that goes to your now defunct computer. Click on that folder and it should bring up the Job Type Page - yours should be set to File (Scan to PC). Select next and it should allow you to enter the name for the new folder and the IP address for the new computer.
I hope this helps.
Nov 08, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
HP PSC 750 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
