I have an Aspire 4520 that will turn on, but no display. Only the light around the power button lights up. I've researched this on the net and tried everything I could fine to do but have had no luck. I hooked it up to my desktop monitor and still nothing. I AM STUMPED!
  • 4,737 Answers
Did you get any signal on the External Monitor? or nothing with only black display? There are several reasons, once you boot the system, listen the boot up sound very carefully and make sure it normally boots up.. Is the hard disk light blinking? If you think the system is not booting up properly or seems stuck at some point, you need to first check the Ram and the Hard disk. Turn off the machine, Remove the battery, unplug the Charger and clean the interfaces (gold contacts) with a brush or cotton bud or a cloth dampen with alcohol or acetone etc...etc.. Once they are cleaned, check the connectors on the motherboard (Ram and Hdd connectors), clean them with a brush... If a Wireless Lan card is installed, reseat it. Now reinstall the Ram (if you have multiple Rams installed, try with only one) and boot up the system without the hard disk, if there is no damage on the motherboard or if there's no bios or display issue, it should show something on the Display...(the black bios/system screen), if so, reinstall the other ram and try again (make sure the system is power off before you reinstall the other Ram or any component, you need to reboot the system everytime you install a new hard to test the status.). Again, check the display, can you see the bios screen (black screen with white text or the Acer Bios screen). If so Turn it off and install the hard disk, now reboot the system, again check...........................
If the system fails once you install the hard disk, then you try booting from a Windows CD, maybe windows xp or any windows cd you can get...if it's successful, you hard disk is bad or corrupted or is damaged.. try reinstalling or repairing the windows, else you need to replace it.
The second cause could be the ram, if in the first place it didn't boot up, then swap the Ram or use a new Ram, that should show you the result about Ram, even if changing the ram isn't helpful, I would assure that it's the Graphics card issue, your only solution is to get it repaired from the Acer service center.
If you can assure that there's nothing wrong with the Graphics card, then it must be the Bios, in the same way, bios can't be repaired from the end users, it needs to be repaired in the Lab, means Acer Service Center.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 10, 2010
My acer aspire 4520 wont start. Plz help me
Hi, Could you please give the details. Is the Notebook not booting up or not turning on ?Please press the power button and check the lights in ur Notebook, whether the power is generating. Please repeat this step when the charger is connected.Also, if the lights are on, then try press "Delete" key couple of times.
Please try out these and let me know the result.
Thanks & Regards,
Apr 26, 2012 | Acer Aspire 4520-5582 Notebook
I have an acer 4520 lap top. I can't get it to power up at all. When I push and hold the power button the green light comes on around the power button and the three lights in the upper right side flash...
first remove your battery and try to switch on your laptop with good power adapter if still have the same issue ?? just remove your memory and reinstall after clean your memory if still have the same issue ?? remove your memory and cmos battery and switch on it with a good power adapter.after 2 minute you can re install back your memory and cmos battery and try to switch on it.
Sep 14, 2011 | Acer Aspire 4520-5582 Notebook
I have an Aspire 4520 laptop. When I turn it on, the green light around the power button lights up, but nothing on the screen. There is power to the system, because the DVD tray opens and closes like it's...
most likely a motherbaord problem.
unplug power cord, take out the battery.
hold power button for approx 90 secs.
try to power up the laptop again.
if this fails then try a new power cord, that could be also faulty and not regulating the correct power output
Oct 10, 2010 | Acer Aspire 4520-5582 Notebook
Acer aspire 4520 does not power up despite fully charged battery and wall adapter turned on. power light blinks for a moment and all other indicators turn on and immediately go off. What could be the...
Remove ur battery & clean it with water and put it in to ur laptop then press 5 minutes ur power button Then ur laptop get started .
Note : Wash ur battery with clean water .
Mar 26, 2010 | Acer Aspire 4520 Notebook PC
I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
Feb 19, 2010 | Acer Aspire 4520-5582 Notebook
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
Bluetooth power
Hey,
to turn it on just press the button or pull the switch, if noting happens or the blue light doesn't light up and the computer doesn't react, it basicly means the computer didn't come with a build in bluetooth device, but has the option for the customer to later install one in the expasion slot inside the laptop.
Let me know if you need anything else.
Thanks,
Ekse
Jan 21, 2009 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
David Payne
David Payne
