Question about Dishwashers
My Whirlpool dishwashers Normal light keeps flashing and won't start
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Service call.
Posted on Oct 10, 2010
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
How do i reset the dishwasher when light is flshing but not run
Hi
To reset the Dishwasher when the light is flashing press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water your incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this insures your unit fills with hot water and not cold.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Won't run - normal light flashes
When I had this problem, it turned out to be the heating element.
Jul 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
