Question about Philips DVD Micro Theater Shelf System (MCD288) System
I have a Philips MCD288 which worked fine until recently. Since yesterday though it cant read cd or dvd's any more, saying "error disc". What do I do? Thanks for your help!
  • 120 Answers
SOURCE: How to play TV sound through Philips Mcd288
You must plug the t.v. audio out cables into an audio input on the philips. left and right audio rca jacks. then you must select that input on the philips to hear the tv. Lawrence
Posted on Feb 27, 2008
SOURCE: Philips HTS 6500 not reading my DVD's
I bought this item in Nov. of '07 and it worked great...for about 3 months then the dreaded no disc message appeared and has ruined my life. Howvever after not using this DVD player for a month or so i had decided to tinker with it to try and get it to work and it appears i have found a solution that is working for me so far. After being fed up with Philips and trying their "solutions" because as we all know the U.S. sells DVD's with the wrong region code (ha funny Philips people) i began trying to make this stupid peice of garbage work in any way. What i came up with is this: 1.) insert your DVD and wait to see what happens. When you get the no disc readings this is what you do. 2) Eject the dvd but do not touch it 3). While the dvd is sitting in the slot press and hold down the play button on the remote control and continue to hold it down 4) it may take awhile but give it a chance, and hopefully the DVD will "resume play" and start anew. If holding the play button down does nothing then try holding it and releasing it in intervals until something happens. If nothing ever happens then i guess you SOL. I know this is not an desired fix to the problem but so far it has worked for me. I noticed this because the stupid thing will would read a cd and this got me thinking. This way is kind of a jump start to get the dvd going....hope this helps someone
Posted on Jul 07, 2008
jaffa012001
  • 376 Answers
SOURCE: Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Posted on Aug 12, 2008
srinivasb81
  • 51 Answers
SOURCE: dvd reads 'load' but nothing happens
This issue will occur only when there is a tray with the motor lens problem so you need replace the entire tray with the motor lens set to resolve your issue.
Posted on Apr 12, 2009
  • 4 Answers
SOURCE: my philips dvd player hts3357
i would like to know too as mine has the same problem. :(
Posted on Sep 19, 2010
Driver cannot read blank disc
I recently installed a dvd writer for my neighbor. they used a top brand dvd-r / rw and never had any problem. but after the new install they had the same problem . after visiting the manufacturer's website we found that that certain brand of dvd were recommended. check the manufacturers site for dvd recommendations.
Sep 11, 2009 | Acer (4432A-002) CD-RW Burner
Region Code
Aug 08, 2008 | Philips MCD288/37 DVD Micro Theater System...
Error recording
It is the disc type that your using or the lens of the disc. Although this unit can use x16, dont. Use x8 and make sure it just says x8. I can assure you it will work hands down. I have this unit. It runs strong since jan 06
Jan 14, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips mcd288 mp3 albums
There's a little bit of work involved, but what you should do is to record those tracks individually as folders, then transfer those to your DVD burner...accordianman
Dec 30, 2007 | Philips DVD Micro Theater Shelf System...
Disc drives
update the drivers once and check again ...
Nov 30, 2007 | Computers & Internet
Says close when i try to play my dvd.
My MCD288 developed the very same issue just 2 months after buying it. I kept thinking than my little niece had to do something with that, and only today, after 2 years decided to open it up and check. Well the problem is the GREY (not the black one) microswitch that is soldered on a little PCB atteched to the CD/DVD mechanism. You can check it on board with a multymeter. It stops working. I unsoldered it, opened it up, cleaned it and resoldered it. It now accepts CDs and DVDs and does not spit them out after a while. If only I could find a solution for the buzzing sound. It must be defective design. Maybe change C560 and C561 on main amp PCB with smaller capacity ones? Or maybe put away the toroidal transformer?
This is the LAST item I'll ever buy from Phillips. Period. They put an unfinished project on sale... Shame on them..
Greetings from Greece
George
Sep 09, 2007 | Philips DVD Micro Theater Shelf System...
Mcd288 problem
Try not to use any rental dvd discs or dvd burner discs. Go get a brand new dvd movie(again,do not burn a DVD disc and play in this unit.) and put it in see if it works? Should have at least 2-3 movies for testing.
If you have tried to put in some BRAND NEW DVD movies and still doesn't work,you have a problem with the unit.
Jul 23, 2007 | Philips DVD Micro Theater Shelf System...
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Philips DVD Micro Theater Shelf System (MCD288) System Logo
55 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
