Question about Whirlpool Duet GHW9150P Front Load Washer
Operating instructions how much to load, run times
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Manuals are online at Whirlpool.
Posted on Oct 10, 2010
Internet explorer wont run on dell laptop, blinks then nothing
Assuming you mean it starts to load, then crashes and disappers. First ensure machine has been restarted. Then if that makes no difference use system restore to go back to a time when it last definitely worked. Without giving your operating system, cant give you instructions how to use system restore, you'll need to look that up. Its very simple and only takes a few minutes and will almost certainly allow IE to load.
Jul 14, 2014 | Dell Inspiron 1545 Notebook
Can't get to load operating programs and can't shut it down to reboot.
Press F8 while rebooting and select start at "last known good configuration" or "safe mode"
good luck!
Mar 21, 2008 | IBM ThinkPad T43 Notebook
Wipe hard drives free
  • There are several pieces of software you can use. I use a program called power Nuke. Simply put the disk in machine restart set Bios to boot from cd rom once it starts it will load the software. then type in auto nuke. Don't wait on it let it run it will take some time. Once it is done close program. Restart and insert new operating system load and follow on screen instructions. you are done.
  • http://www.download366.com/dban?utm_source=google&utm_medium=cpc&utm_campaign=366_USA_en_longtail_Utilidades&utm_content=DBAN-(Darik%27s-Boot-and-Nuke)&utm_term=dban%20download&gclid=CLzFvtD36b0CFcURMwodWSgAzg
Apr 18, 2014 | Compaq Computers & Internet
What happens wen rtc Batt is unloaded
Hello. batt files or batch files are used by your operating system to run a list of commands created by ms-dos or by you. A good example of a batch file is the autoexec.bat which is loaded each time the computer boots to MS-DOS. Batch files are like shortcuts on your desktop, when they are run they pass information through the command line and these sets of instructions run commands or programs on your computer. Did that help?
Feb 09, 2014 | Acer Predator G3620-UR308 - Core i7 3770...
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
How to install MS word
insert the Microsoft Office CD/DVD into the drive. Wait for it to load. if it does not open it through the windows explorer and open your CD/DVD drive and run setup. Just follow the instructions on the installation. you would just normally just click next most of the time. When prompted for the cd key or the serial look for that data from the box or the cd case.
Oct 04, 2010 | Microsoft Computers & Internet
The power cord keeps overheating
Hello there:
this could be a wiring problem from the factory where the cord is unable to handle the load thus resulting in the cord overheating .
Or you might have the setting too high making the unit run constantly and now getting any time to cool itself down.
i would refer to the operating instructions and do what it tells you to do and if you still recieve unsatisfactory operation i would take the machine back to the place where you purchased it. ok?
best regards michael
Oct 03, 2009 | Heating & Cooling
My dryer takes much longer to dry loads now
Hi!
You need to check the following things to sort out the issue you are facing with--
Improper sorting •Separate heavy items from lightweight items (generally, to dry a well-sorted washer load is a well-sorted dryer load).
Large loads of heavy fabrics •Large, heavy fabrics contain more moisture and take (like beach towels) longer to dry. Separate large, heavy fabrics into smaller loads to speed drying time.
Controls improperly set •Match control settings to the load you are drying.
Lint filter is full •Clean lint filter before every load.
Improper or obstructed ducting •Check installation instructions for proper ducting/venting.
•Make sure ducting is clean, free of kinks and unobstructed.
•Check to see if outside wall damper operates easily.
•Check the Installation Instructions to make sure the dryer venting is correct.
Blown fuses or tripped •Replace fuses or reset circuit breakers. Since most dryers circuit breaker use 2 fuses/breakers, make sure both are operating.
Overloading/combining loads •Do not put more than one washer load in the dryer at a time.
Underloading •If you are drying only one or two items, add a few items to ensure proper tumbling.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Thanks
Rylee
Apr 03, 2009 | GE DVLR223 Dryers
Error : loading operating system
plz try to boot in safe mode run check disk and then boot normally, if the problem arises then try by repairing the operating system. plz post your findings
Jan 12, 2009 | HP Pavilion ze2000 Notebook
My ibm t40
If there is a problem in loading the operating system it may have been caused by some change. If you can work out what stopped it from working then you can try and reverse the change. Alternatively you can try to reinstall the operating system, to do this you insert the system disk that should have come with the computer or the OS if you upgraded it and follow the instructions. You may have to fiddle around with the startup options to get it to run the disk. Most computers access these through pressing F8 somewhere in the startup sequence.
Dec 01, 2007 | IBM ThinkPad T30 2366 Notebook
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
