Question about Lakewood HV 18-c Floor / Box Fan
I have a floor fan with a bad capacitor. its a 1.5uF +-5% 450V. can i replace capacitor with a 33 uF 250 ~ 275 V capacitor ? or with some other one that i got ?
No, the capacity is way too high.... get a capacitor of at least 1,5 uF or up to max 4 uF if you happen to have one lying around
Posted on Oct 24, 2010
  • Lakewood Master
  • 43,501 Answers
No,
You will need to have one with the same voltage...450V and it will need to be a 1.5 or 2 uF for it to work...
heatman101
Posted on Oct 23, 2010
2 capacitors are in the condenser unit. 1 ceramic, 189-227 mfd. would that be for the compressor? the other is aluminum, 35+5 uf. would that be for the fan?
the 189-227 is a start capacitor for compressor. the dual capacitor is 5 uf for fan and 35 uf for compressor it serves as run capacitors.
Sep 14, 2015 | Heating & Cooling
My Central Air Conditioning system does not seem to be blowing air. Yet, the compressor is working but the compressor capacitor reads 19 uF instead of 35 uF which is rate for. I noticed that the blower...
First replace the cap for the compressor. then find the cap for the fan. It should be with the compressor. We have seen alot bad caps this year. Ihopes this helps.
Aug 25, 2011 | Ruud UAKA037 Air Conditioner
My Goodman CKL30-L1 is turning on but the fan will not spin. Any suggestions????
access the electrical cover on the corner of the unit after disconnecting power and inspect for loose wires or bad capacitor, the capacitor has three different terminal connections on top and the top should be flat not bulged, if bulged,rounded in any way then the capacitor needs replaced. If the fan motor still does not work, then the motor will also need replaced. Note: capacitors can go bad without bulging or swelling, a meter for testing capacitors will verify uf(MFD)rating as printed on part.
Aug 24, 2011 | Goodman CKL60AR60 Air Conditioner
After 8 months, fan will not start. Check 3 speed switch..OK, checked motor coil...OK check 110V supply...OK 5 microfarad start capacitor fails to charge/discharge. Need replacement, but can not find...
The latest Jameco electronics catalog (www.jameco.com) has a 5 uF 370 volt motor-run capacitor for $1.95. It may however, be too physically large to fit in the motor case. Hope this helps!
Aug 14, 2010 | Lakewood HV9 Floor / Box Fan
Need C61 E185116 capacitor for a Harbor Breeze fan...what makes the melt? Are the fans safe ?
I have a 3 wire 1.8 uf and 2.7 uf fan capacitor. Mfg suggests to replace with 3 wire 4 uf and 5 uf. What will this do ? Any harm.
Jul 09, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
YORK CONDENSING UNIT MODEL H1RA042506D WIRING SCUMATIC BLOWER MOTOR WILL NOT START WITH OUT A PUSH. START COMPASITOR MAY BE BAD BUT WITCH ONE IS IT. MOTOR NAME PLATE CALLS FOR A 370MFD. I FOUND A 36MFD...
The capacitor for the fan will read 370uf 5 uf. The 370 is voltage at cap. My guess would be a 7.5 uf cap for your fan. If you read the cap. it will tell you size. Fan caps go between 5 and 20 uf or microfards. Easy to replace you can do it yourself. Rus
Oct 29, 2009 | Heating & Cooling
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Fan motor not I have two caps and dont know which
First pull the quick disconnect (power source). If you have a multimeter with capacitor check (uf) capabilities, look at the side of the capacitor and see what the uf rating is, (should be somthing like 3.5uf or 5.0uf or7.5uf) then stick a screwdriver between both contacts where the wires are pluged into the top of the capacitor and touch both contacts at the same time to discharge any stored electric power, then remove all the wires from the top of the capactor, switch on the multimeter and set it to the uf setting, now place one lead on one side and one on the other, if your capacitor is say a 7.5uf and the reading is 9.0uf or 6.0uf it's bad replace
the capacitor. check both of your capacitors the same way, oh mark your capacitor and the wires so you can put them back together rite. If you don't have a multimeter with capasatence checking capability take them to an appliance shop and let them do it for you.
Jul 03, 2009 | Ruud UAMB Air Conditioner
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Aug 06, 2008 | Westinghouse Fans Indoor Ceiling Fans
Lakewood HV 18-c Floor / Box Fan Logo
573 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
