Question about Car Audio & Video
Iv wired up my subwoofer and it only kicks in when i turn it up very loud, its like it needs loads just to kick in could you help ???
  • 112 Answers
Make sure you have LOUD selected in yr audio menu
Posted on Oct 11, 2010
When i turn da radio off then turn the beat on it work n stop
I don't know if your talking about subwoofer or speakers but if they stop while a big loud beat comes in its to much for your amps if you have them to handle and the amps turn of and by turning of your head unit and on again it resets them and works again try turning your gain down on the amps
Aug 01, 2014 | Car Audio & Video
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
Hello iv changed the piston on my kids honda xr 50 now it wont kick over i can move the piston through the head pulling the small chain in the cylinder head about 2 turns of the coge the opposite way to...
It sounds like you have not set the cam chain timing. If the cam is not timed to the piston position, the piston can come up and hit an open valve. If you put the engine together and kicked it over so the kick jammed then the piston has hit an open valve and chances are very strong that the valve is now bent. Bummer... If bent badly enough the valve guide may be cracked as well. Double bummer... I would pull the head off and do a visual inspection of the valves. Do they LOOK fully closed? Can you see a strike mark on the top of the piston? If all looks good, I would put the head back on then set the cam timing then turn the flywheel over by hand a full four revolutions. If it doesnt bind up you should gently push the kick lever to turn the engine over a few times. Okay, the piston doesn't seem to be hittinng a valve. Now do a compression check. You want to have 130 to 160 psi. If you do, the valves are okay. Get back to me by posting a comment if you don't know how to set the cam timing. The following diagram may be self explanitory. Please rate my answer. Thanks.
Feb 21, 2010 | 2002 Honda XR 200
I dont know how to connect it .it is an mrp-m850 i tryed to connect it but it wont turn on
well u run a power wire atleast 4 guage from the positive terminal on the battery, then 4 guage to a chasis ground source, then a remote wire to the rear of your cd player that will kick the amp on when the cd player turns on... then for subwoofer wiring go to www.the12volt.com for sub wiring options... you need either single voice coil 4 ohm subs or 2 ohm dual voice coil subs to get the 2 ohm load to the amp so u can get the rated power out of it...
Dec 06, 2009 | Alpine MRP-M850 Car Audio Amplifier
Older Harman Kardon computer speakers have loud hum
The hum (50 or 60 Hz) is caused by the AC power getting into the entry point of the amplifier. Either the filtering capacitors from the powersource of the speakers have dried up - replace them - or there is a short in the cables.
There is another possibility: if you have kicked the subwoofer  box its transformer might have slipped from its fixings and now is touching the subwoofer speaker frame.
The only way to find which is to open the cases.
Nov 28, 2009 | Harman Kardon HK695 Computer Speakers
Multi speed fan on Gateway too loud..
You may have more than one fan.
The fan in the power supply may not be replaced, but you can replace the switch mode power supply with a newer model that has a larger fan that is very quite.
The same goes for the second fan (if you have one) that is inside the case.
Most computer suppliers have better designed and quiter fans.
May 18, 2009 | Gateway Computers & Internet
Powered Subwoofer hits hard even on dialogue.
This sub doesn't have a gate (keep the sub from engaging when the source level is low) so it'll "hit" for any input signal. What it does have is an adjustable frequency low-pass filter. If it's kicking in for sounds that don't need big bass reinforcement, try turning the filter to a lower number. The sub will then only kick in for really deep sounds.
Apr 23, 2009 | KLH ASW10-120 Subwoofer
Yes i have a 1000 watt amp and when i turn it on it stays on fine until the bass hits and then it kicks off then it kicks back on and the problem reaccures
I believe you have your gain on the amp turned up to high. Try turning the gain down, or if you have a LOUD button on your headunit turn it off
Hope this helps
Apr 06, 2009 | MA Audio MA 1200XL Car Subwoofer
Do I wire 4 ohm voice coils in series or parallel to get a 2 ohm circut?
Basically, it would be the amp that would dictate whether series or parallel. If the amp is rated at X watts @ 2 ohms, then the speakers could be wired in parallel. If however the amp is rated at so many watts in 4 ohms, then it would be safer to wire the speakers in series to achieve 8 ohms.
If two 4 ohms speakers are wired in parallel, the end result is a 2 ohm load. If the amp is rated at 4 ohms, and presented with a 2 ohms load, possibilities are:
  • autoprotect would kick in often;
  • burn the output transistors of the amp.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
