Question about Envision 19" Widescreen Flat Panel LCD Monitor
MY monitor keep going all black everytime then i have to press the on button to shut it off then press it again to come back to normal then it goes all black again then i have to do the same thing..
  • 11,361 Answers
It has dying power supply DC filter caps, taht will be the first place to check.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 10, 2010
I have a w1907 HP monitor. It keeps displaying a small box in the middle of the screen that says osd lockout. I am still able to get online and use my computer normally except for this box in the middle of...
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work. To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Jan 03, 2011 | HP w1907 LCD Monitor
"OSD Lockout" keeps poppoing up on the screen. I
-turn of the monitor first
-when the monitor is off press and hold the menu button on your monitor
-while holding down the menu button on your monitor power it on
Nov 22, 2010 | HP w1907 LCD Monitor
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
Screen goes black
Could be a loose cable connection the cable that runs between the LCD and the laptop my come loose from time to time and the screen will go black you have to be carful with this because you may be shorting out the inverter and eventuly you will have no picture it should be and eas fix if the cable is loose Go to the manue or service guide and find out how to open the Lcd cover behind the Lcd sceen there should be a connector make sure it is properly connected
Mar 24, 2009 | Compaq Computers & Internet
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Monitor goes blank after 5-10 minutes
You may have a compatibility issue with your monitor. You computer may not be putting out enough power to support your monitor. Check your users manual on your monitor for output requirements. If the monitor's manual has a number to call, call the manufacturer to see if there are any compatibility problems between your computer and your monitor and calling the people who built your computer as well. Get as many scenarios as you can to find a solution. Hoped this helped.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Envision 19" Widescreen Flat Panel LCD Monitor Logo
135 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
