Hi. There are 2 versions of this router Go here http://www.dlink.com/products/?pid=DI-614%2b&tab=3 and click on your model. (reg or B revision) This will allow you to download any available resources like users manuals, any software or firmware updates etc..
The factory default User name is admin and the default Password is blank (empty). It is recommended that you change the admin password for security purposes. Please refer to Tools>Admin to change the admin password.
1. this error is not recognizable. But here is the D-link site for updating your firmware for the DI-614 this may resolve your issue. http://www.dlink.com/products/?pid=DI-614%2b 2. You also may want to check the status of you router by logging into it and checking the "status" page (192.168.0.1) User : admin No password unless specified This will tell you a lot as to what the router is doing and not doing.
I don't know for the 614 as there isn't a model like that... Your picture shows a DI-514. Here is the process for that model.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do the following: • Leave the device powered on, do not disconnect the power • Press the reset button and hold (use a paper clip) • Keep the button pressed about 10 seconds • Release the button The DI-514 will then automatically reboot itself.
If you truly have a 614, can you post more about the model number? It's usually written on the bottom of the router.
Between the ethernet * power ports is a tiny hole. Inside this hole is the reset button for this device (looks to fit perhaps a paperclip). Here is a link to the user manual for any further questions with this device : ftp://ftp.dlink.com/Gateway/di614%2B/Manual/DI-614%2B_manual_06292005.pdf
Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Have you left enough space around your DI-614 to discipate the heat? Maybe it is overheating.
Also, the problem may be with the power supply and not the DI-614 itself. D-Links tends to use the same type of power supply across many models. If you (or a friend of yours) have another DLink device, you may trying using its power supply. Before doing that, make sure that the power supply of your DI-614 and the other one have the same rating. The rating is indicated on a sticker on each power supply.
By the way, opening the cover will void your warranty, if the device is still covered.
