Hi Rylee
Thanks for using FixYa. To start with check the drain hose, if that's clean
and not clogged then the issue is with the Timer/Control going bad and should
be replaced. Please accept the solution if the issue is resolved or post a
comment with complete model no# for further assistance.
Thanks
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
drain hose was blocked. Back on cycle and appears to be fixed.
Thanks for the assistance.
