Question about Dell Dimension 4600 PC Desktop
Transfer data from Dinension hard drive to XPS hard drive
Exactly how doI go about making the hard drive of the Dimension a slave drive to transfer its comtents to the XPS? That is a new concept for me. What type of adapter would I need if the slots don't match? Where is the hard drive connector?
Thanks,
Amy
  • 242 Answers
If you have no experience with this, it might be easier to just copy the data from your Dimension to a external usb harddisk and then to the XPS. But i will try to explain it.
I've looked a bit around: your XPS hard drive is a SATA drive, while your the drive in your Dimension is probably a PATA-drive (just connection types. Look at the hard drives and compare them with this image to see which types they are.)
As far as I know the XPS 530 has a Foxconn G33M-S motherboard, which contains one ATA (PATA) connector. So you should be able to just connect the hard drive from your Dimension into the XPS.
To make it work properly, you should set the drive from the Dimension to slave. This can be done by setting the jumpers next to the cable connector. The jumper setting depends on your hard drive model. Usually the possible settings are shown on the hard drive.
If you feel uncomfortable with this whole thing, you could ask someone, who has some experience and who you trust to do it for you, or just use an external usb hard disk
Make sure the computers are off and disconnected from the power outlet, when you open the case...
Dell offers a user manual for your Dimension and XPS. Maybe it's of some help by removing and placing the various parts...
Please tell me how it worked out.
As you probably understand, I can't take any responsibiity for damage to your system...
If you have any problems, just post them here!
Posted on May 31, 2008
How do I add a slave hard drive to a computer
Is it an ide (flat wide data cable & 4 cable power cable) hard drive? There will be jumper pins near the data cable socket to set one as master and the other as slave.
Jan 05, 2012 | Dell Computers & Internet
Dell Dimension 8400 running xp has died. Can I put the hard drive into a spare slot in a Windows 7 PC to get the data off the XP HD?
Two Options:1. Yes you can as long as your Windows 7 PC has the correct connection for your hard drive. Most likely you need an IDE connection. If you have an IDE hard drive and the Windows 7 PC has an IDE connection, then you will need to make sure to "slave" the hard drive by moving the jumper on the hard drive to slave mode.
2. If your Windows 7 pc doesn't have an IDE connection, the purchase a USB to IDE cable adapter:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770
This way you can plug your hard drive into any computer through USB.
Best regards,AbdielComputer repair plantation
Oct 27, 2011 | Dell Dimension 8400 PC Desktop
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Transfer old hard drive to new computer
saharris
yes, u can attached this drive with ur new pc and transfer data. u also can use with it. if ur drive with PATA interface when u connect in same cable with other PATA drive u must configur one is master and other slave.
Jul 10, 2008 | Computers & Internet
TRANSFERRING DATA
Hello Betty,
The way you do it is mouting your old hard drive as 'slave' on your new computer..(if it's not the same).
do you have any experience on computer hardware?
Jun 28, 2008 | Dell Dimension 2400 PC Desktop
Transfering data from one desktop to another through LAN connection
you have to put the cable in the ethernet card (or network card) it looks like telephone connector ( it will be big in size)
May 31, 2008 | Dell Dimension 4600 PC Desktop
sol 1 you can burn your data in dvd or cd
sol 2 you can transfer your data in thumb drive (pen drive)
Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
May 22, 2008 | Dell Dimension 8400 PC Desktop
Dell Dimension 4600 PC Desktop Logo
78 people viewed this question
Alun Cox
