Question about Amana ACF3325 Gas Kitchen Range
How do you get the oven door to unlock after cleaning?
  • Amana Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Oct 11, 2010
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Cannot unlock oven door
  • Here it is!
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    The lock will not release after cleaning
    This is GE's trouble shooting advise:
    Range - Oven Door Won't Unlock After Self Clean
    The Oven Door has been Locked Accidentally:
    • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
    • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
    • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
    • Note: Do not force the latch at anytime!
    Door Will Not Unlock After Cleaning:
    On models with mechanical latches:
    • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
    Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
    If the above suggestions do not work try the following to unlock your door:
    1. Disconnect power to range for 30 seconds.
    2. Reconnect power and see if door will unlatch.
    3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
    4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
    5. Wait approximately 30 minutes and try to unlock the door.
    6. If the door unlocks, the control has reset itself and there should not be any other problems.
    7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
    Note: Under no circumstances should you ever force the door or latch open.
    May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
    Oven door won't unlock
    kenmore selfcleaning oven door will not unlock code f9 appears in window
    Jan 03, 2010 | Ovens
    Oven door remains locked after using the oven cleaning feature
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Lover oven door did not unlock after cleaning cycle.
    if it is cooled enough then try this
    hold back and enter hold for three seconds , unlocking door will appear in display when control and door are unlocking
    good luck
    Jan 29, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
    Cant unlock self clean oven door
    Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
    May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Open Questions:
    Amana ACF3325 Gas Kitchen Range Logo
    110 people viewed this question
    Top Amana Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal De
    Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
