Question about Dyson Vacuums
My Dyson DC 14 is about 5 years old now and when I push the on/off switch it starts, but it won't stay on unless I hold down the on/off switch.
  • 377 Answers
Sounds like you would have to get the on/off switch replaced. You could try one thing prior to trying to replace the switch or taking it in for repair. After 5 years of use there may be some dirt that got into the switch. Unplug the unit and spray some Contact Cleaner (available at Radio Shack) or some WD 40 into the switch area. Use a bit of it so it can work its way into the switch. Then, here comes the good part, turn the switch on and off for a few minutes. The action will somewhat clean the contacts of the switch IF the cleaner was able to get into the switch. If you try this and it does not work, the next step I would take would be to disassemble the unit and get at the switch to see if wires have come of and if they have not, check the continuity of the switch and last ditch fix, replace the switch. Paul
Posted on Oct 11, 2010
  • pwillitz Oct 11, 2010
    Thank you very much for the great rating, I appreciate it as well as the fact that you took the time to do it.
    Paul
My dyson dc 25 turn on but can't stay on unless you hold the red button on?
If it use to click on and off, but does not anymore replace the switch.
Aug 31, 2014 | Dyson Vacuums
My Dyson - DC14 won't push on my new plush carpet, front end
Same issue: new plush carpet, 7 year old tried and true DC14, wouldn't push across regardless of beater brush on or off. Called Dyson this morning, they suggested removing the small gasket between the floor plate and the assembly holding the beater brush. It's about a 12' gasket just under the screws used to remove the floor plate. Pushing is still a bit stiff, but it is a definite improvement. Whew!
Jul 29, 2012 | Vacuums
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
The on button won't stay on unless I hold it down.
Sorry to hear you're having a problem with the switch on your DC07. Please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so one of our experts can advise the best course of action.
Kind regards,
Jack
Jul 25, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Older dyson dc 14 control knob for swithing from carpet to floor
Most likely you need to replace the clutch assembly. This video will show you how to replace it.
May 26, 2010 | Dyson DC14 All floors Bagless Upright...
My Dyson DC-17 Absolute Animal does not stay running after I push start button. It will only run if I hold the start button down all the time.
switches always fail on the dysons. its a pretty simple fix though. let me know if you need parts and/or instructions on repairing it.
Apr 12, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Vacuums Logo
392 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
