SOURCE: Cannon pixma ip1700 not printing
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
SOURCE: cannon MP210 printer
Make sure the printer ink cartridges are set in all the way. If it is not properly set in place, printer will not work correctly.
SOURCE: cannon printer feed paper
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
I tried this and it worked (thanks to a suggestion from someone else but can't find his name right now) --
I found a slender piece of cardboard, the front off one of my 1-subject notebooks. I cut the jagged edges off, made sure there wasn't any debris or loose crumbs of paper. Put about 20 sheets of paper into the printer and put this cardboard as the first sheet. Pressed the copy button. When it started to attempt to feed, I forced it through.
What did it find?? A moth had flown into the printer at some time, gotten smushed, smashed and stuck -- and was preventing the paper from feeding through! OMG, I almost tossed this Canon MP210 in the garbarge.
So thanks to you guys with ideas about cardboard and a little muscle. I ran another piece through just to clean out all the stickiness (and the remnants of the moth's body). Works fine now.
webstuff
SOURCE: Paper not feeding into printer: pulls to the right and jambs
Great tip, Yooperbud, it worked for my Canon MP210!
