Question about Meade LX200GPS Telescope
I have a meade lx200gps 10" scope. The ra up is not responing. the down is working only. After initializing and fining north the auto star says stalled motor.
  • 3,186 Answers
Do a calibrate motors and make sure you are using a separate 12 volt power pack or BRAND NEW internal batteries. All goto scopes work better with smooth, regulated power. The internal batteries will NOT work well for very long.
The Calibrate motors routine adjusts the motors for the power supply being used.
Posted on Oct 13, 2010
I just purchased a used Meade LX200 10" scope by mail. When I opened the box I found that the battery compartments AND the sheathing on the inside of both arms are missing. Have I been ripped off?
I assume you mean by sheathing the cabling to the RA and DEC motors and by battery compartment the control panel. If the seller stated that the scope was working, indeed you got ripped off. If by ratings you mean ebay I would contact them about a return and refund. If you got a great price, all is not lost since there is an upgrade to an autostar which will get you back in working order (but you need the RA and DEC motors). Autostar upgrade is about $ 520 but you will still need a 12V power supply. George Dudash 760 383 2741 sells these kits and can probably get the other parts you need to get going. I'm guessing this may cost around $ 800 total from what you say. If you paid more than $ 1000 for that scope I'm afraid you were ripped.
Mar 01, 2015 | Meade 10" LX200GPS Schmidt-Cassegrain...
Continuous RA motion
This could the problem with software failure please unplug the unit from any power source for 30min and power it back if possible set to default factory setting and check its working....
Good luck...
Jul 27, 2008 | Meade LX200GPS Telescope
Scope is 12.5, 9 years old. We align by going to "named star," selecting one, slewing, correcting, hitting synch. Repeating with another star. Almost always the scope goes to accurately there after. (We...
Runaway DECLINATION is what this is called. Usually it can be fixed with a new hand controller cable. If a new cable does not fix it, then it has a blown motor circuit board and must be returned to Meade for repairs.
Meade customer service:
http://www.meade.com/support/index.html
Aug 18, 2010 | Meade LX200GPS Telescope
Meade LX200GPS 16" out of calibration?
Before you panic I would update the firmware/software on the telescope. With an LX200 interface cable you can upgrade the software in your telescope from your PC by going to Meade's web site at www.meade.com
Download Meade's ASU (Autostar Update Utility) and the latest software for your Autostar II absolutely free. You can also use the ASU to add Comets, Asteroids, Satellites, and User Objects to your Autostar II with a few simple clicks of the mouse.
I believe you can get the manual here.
Jun 04, 2010 | Meade LX200GPS Telescope
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
I've made every possible alignment on my 10 inch Meade LX200GPS telescope, training,set-up, calibration, etc...but when I slew to a star....it is ALWAYS very far off in Dec....though RA seems to be well...
You might want to join the following Yahoo group:
http://tech.groups.yahoo.com/group/LX200GPS/
I am not familiar with the LX200, but there are probably folks on the Yahoo group that can help.  The only thing I can think of is if you are using a wedge and the wedge isn't at the correct angle (should match your lattitude).  Or you are not using a wedge and the Meade controller thinks that you are.  But one would think the calibration would solve that.
Apr 26, 2009 | Meade LX200GPS Telescope
Azimuth motor stalling missing the electronic home sensor
Check for binding in the gears; my 10" had aluminium chips in the fork base that jammed the gear. Cured by removing the RA manual adjust assembly - was useless anyway, as it could only be used with the RA unlocked. One setscrew in the fork base holds it in place,just loosen and pull up.
Apr 16, 2009 | Meade LX200GPS Telescope
Calibrating & Aligning the Meade 10" LX200 GPS Telescope in the Southern Hemisphere
  1. Do a Calibrate Sensors
  2. Do a Train Drive in RA and also DEC
This makes sure that the scope is calibrated properly.
  1. Do an AUTOMATIC ALIGN
  2. when asked to center star, look for the BRIGHTEST star that is close to the scopes field of view. It will be that star you need to used the arrow keys on to centre it in the scope eyepiece and press enter.
  3. This star can be as much as a HANDS distance away from the centre of view
  4. If you cannot identify the star it is asking you to use, press the SCROLL DOWN key to choose another star, keep doing this until you see a star you recognise.
That's it!
You can also hold down the MODE key for about 4 seconds and scroll through the scope info. Make sure you have the correct location coordinates ( Lat/Long) and the correct time set.
Select a bright object first such as a planet and GOTO it. Once you have manually centered it in the eyepiece, press ENTER and hold it for 6 seconds, the handset will say " Press ENTER to sync", press enter and you have updated the scope with the coordinates of that object.
Oct 20, 2008 | Meade LX200GPS Telescope
My great Meade LX6 10 ", F/6.3 scope...has developed a vexing problem in the hand paddle controller attached to the RA & DEC encoders. After starting to initialize or boot up....it suddenly goes...
My scope sat in a basement for years and when I started it up I got an error the same as you discribe. Through sear luck I found it to be a bad connection where the encoder wire pluged into the battery box.
Apr 25, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Meade LX200GPS Telescope Logo
157 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
