Question about Intel DG41RQ Motherboard w Pentium Dual Core E5400 Processor w Fan Bundle (BOXDG41RQ W E5400)
I have intel board DG41RQ -E5400 ,2.7 dual core procesor with 1gb ram ddr2,400w power supply,500gb sata hard drives. i recently bought this system but my 5 hard disk are damaged.please tell me is this a board problem or power supply issue. my board are still in warenty.
  • 4,737 Answers
In my opinion Motherboard issue, but I can't assure, it could also be the Power supply, as bad power supply could cause the motherboard mal-function and is causing the hard drive failure. If the motherboard is under warranty, you better get a replacement than wasting another Hard drive, and I hope it's better for you to replace the power supply as well, you'll spend less buying a 450watt power supply than buying a new 500gb hard disk.
Also make sure the cabinet is properly fitted and the ground is working without any problem, you can check this by using a tester (screw driver tester) after it's connected to the mains, or you can try with your hand (it'll not kill you :-], but I don't recommend if you have a screwdriver with tester).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 10, 2010
E5200 drivers
Hello the drivers can be downloaded here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
But first select your windows system.
And heres the ram support:
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029920.htm
Your mainboard supports DDR 2 ram, up to 8 gb.
Please select a quality brand, the cheap ones does not last long.
Good luck
Jun 24, 2013 | Intel DG41RQ Motherboard CPU Bundle - ...
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
How much gb hard disk support to Intel motherboard dg 41 WV
Intel G41 compatible with core 2 duo can support any Size of SATA Hard disk drive (Storage Device).
vote me if found helpful.
Aug 06, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
What is max.hard disc size supported by intel DG41RQ mother board(can it support 1 TB+80GB)?-help me please sir..................
Any motherboard that is modern-enough to support "dual-core" processors can support *ANY* size of SATA disk-drive that you can afford to purchase.
Jun 21, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
My desktop, of three years, no longer does a POST. The screen remains blank after the system is powered on. The M/B is an Intel DG41RQ. The processor is the Intel Core 2 Duo, 7400. The operating system is...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 02, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
My Intel Board DG41RQ beeps once at start up and after that it comes up with the Intel screen. After that it beeps once again and then starts to load the operating system.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Apr 02, 2011 | Intel DG41RQ Motherboard CPU Bundle - ...
What computer parts will be bought?
Following are the things you have to keep in Mind.
1. Processor
2. Motherboard
3. RAM
4. DVD drive (Writer will be good)
5. Suitable Casing
6. Hard drive.
7. Speakers/Headphones
8. Power Supply
9. Monitor/LCD panel
10. Keyboard
11. Mouse
Buy all these things and you can make up a basic Desktop system.
May 28, 2010 | Computers & Internet
How much is my computer worth
Based on brand new parts:
500GB SATA - $56
160GB SATA - $45
4GB RAM - $112
V-card - $105
CPU (Proc., Mobo, P/S, reader) - approx. $107
Your rig can be sold at around $425 - $450 approximately.
Hope this helps.
I had assembled a Quadcore system at around $750.
Mar 20, 2010 | Computers & Internet
Intel DG41RQ Motherboard w  Pentium Dual Core E5400 Processor w Fan Bundle (BOXDG41RQ W E5400) Logo
142 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
