Question about Whirlpool Dishwashers
The soap dispenser on my whirlpool dishwasher sticks doesn't always open far enough for the tablet to dispense. how do i fix it
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
I always bust the little tabs befor i put them in, or just toss them into the machine bypassing the door altogether. Works just fine. That little door is for powder or liquid most times.
Posted on Oct 10, 2010
Detergent cake left in dispenser after wash cycle
Has the dispenser door open at end of cycle. If dispenser door is open but not fallen down to the tub means most likely the water arm pressure is not good enough to get flush down to the tub.
Door not open means dispenser failure or control board not giving power to dispenser at right time. In some cases dispenser door is stuck with harden earlier soap so it cannot open completely in the cycle.
Why not when opening the door at end of cycle, listen to dispenser area to see the flapper opening while you are opening the door. That means dispenser not opening properly in the cycle.
This issue is a hard solve sometimes. Don't wont to spend the money, then just use the tablets and through them in the tub in the beginning and say good bye to dispenser.
Apr 06, 2015 | Whirlpool ADG450 Slim-Line Built-in...
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool dishwasher DU920PFGZ0 and the detergent dispenser door doesn't open all the way to release the soap
Is there a tall dish/cookie sheet/pan blocking the dispenser door from opening fully? Check inside the rack of the dishwasher to see where the dispenser door lines up.
Oct 11, 2011 | Whirlpool Dishwashers
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The soap dispenser sticks and the tablet doesn't come out
heatman101
Oct 10, 2010 | Whirlpool Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Dishwashers Logo
89 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
