Question about Maytag MEW6530DDS Stainless Steel Electric Single Oven
How do I get the keypads on my Maytag oven to start working again ... Is this something I can fix myself, or does it require a professional?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Unfortunately your going to have to call a service tech out, unless you have a programming manual.
Posted on Oct 10, 2010
I have a maytag wall oven it shows error code f2eo what does this mean and how do I fix it?
E0 F2 is usually a stuck key on the keypad. You will need to replace your keypad most likely. It's possible to be caused by the control board also. If it is NLA we can rebuild it for you at fixyourboard.com
Aug 13, 2015 | Maytag Ovens
Replaced control board and keypad but oven buttons still not working
I pulled the schematic there is a thermal fuse on the neutral wire going to the control you should have 120VAC at terminals P4-3 and P4-1 if not find the fuse back trace from P4-1
Feb 12, 2014 | Whirlpool Ovens
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
MEW6530DDS keypad not working
Check out www.appliancepartssolutions.com for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
Aug 06, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Bake button and numbers on the keypad have stopped working
HI, this is a touch pad issue but, due to the integrated design of the control board and touch membrane, you will have to replace the entire control board in order to fix this issue. you can purchase this board at the link below.
CLICK HERE
May 20, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
F7 code keeps flashing, nothing on keypad works. I can use second oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will...
After much searching, I have found that you have a faulty keypad.
The recommended solution is to unplug the oven, or shut it down at the fuse box, and then remove the faceplate where you can then remove the keypad, and clean the connectors with an eraser, as well as the ribbon that connectes the keypad with the oven.
I hope this helps out.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
Maytag oven keypad not working
my oven is not working, the grill works and the rangers too.
i don't know what to do .
please can you help me
thank you
Oct 20, 2008 | Maytag MEW5530D Electric Single Oven
Touch pad
it requires a professional due to electrical connections
Feb 19, 2008 | Amana AEW4530DDS Electric Single Oven
Maytag MEW6530DDS Stainless Steel Electric Single Oven Logo
139 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
