Question about Fossil Metal Dress Tiffany ES1510 Watch for Women
What kind of battery is used for a ES1510 fossil metal tiffany watch for women?
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
SOURCE: How to remove links from Fossil metal band?
I did not know this was this easy, all this time with this problem. I like the internet.
Thanks!
Posted on Sep 04, 2008
SOURCE: link pins for a womens Fossil watch
The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
Posted on Oct 27, 2008
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
slp11508
  • 43 Answers
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
Battery number for fossil es1741T9
Take your watch to a jeweler for battery identification and perhaps replacement.
Jun 26, 2014 | Fossil Metal Glitz Glitz White Dial ES1741...
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 12, 2011 | Fossil Blue watch #AM3574 Watch for Men
I have a Fossil AM-3719 watch. I bought it in October and it just stopped working. Shouldn't the battery last longer than that? Where can I get another battery? I'm located in London, Ontario, Canada.
Before you take any action which may invalidate your warranty, have a word with Fossil costumer service (go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html).
All the watches that I have owned ran for more than a year and Fossil may sort it out for you.
Apr 11, 2011 | Fossil Casual Metal Dial AM3719 Watch for...
How to adjust a metal watch band Fossil Casual Metal Dial AM3861 Watch for Women
mcdevito75 here, Best bet since you would need a couple of tools to adjust the band size is to look for a small watch repair shop in your area to save on the cost, the cost of a shop to adjust the band is about the same as the tools needed, since these adjustments are in frequent let the watch repiar shop do the job.
Jun 18, 2010 | Fossil Casual Metal Dial AM3861 Watch for...
Which battery for my Fossil ES1112?
I believe the battery is a type 364. Here's a link to an article on changing the battery. Good luck!
Mar 04, 2010 | Fossil F2 Dress watch #ES1112 Watch for...
WHAT TOOL DO I NEED TO REMOVE THE BACK OF FOSSIL BLUE #BQ-9232 AND HOW AVAILABLE ARE THE BATTERIES FOR REPLACEMENT?
Most watch backs either screw off with a special case opener that every wachmaker uses or pried off with a knife like case opener or sometimes a knife. Take this to your local watchmaker for battery replacement. Batteries are readily available but are a bit tricky to install properly and are best installed by a qualified watchmaker.
Nov 29, 2009 | Fossil Metal Chronograph White Dial ES1793...
How do I remove the back off a fossill watch to replace the batteries
If it doesn't have the indentations for a tool used to screw off the case back then its a pry off type and you need to use a sharp tool and pry off under the case against the band post
Nov 06, 2009 | Fossil Metal Chronograph White Dial ES1793...
One jewel fell out can i get a replacement
The short answer is no.
You might find a specialty shop that would have a replacement but my experience has been that you will need to get a replacement band or case from Fossil . You will end up paying for this because Fossil's warranty doesnt cover cosmetic damage.
Sep 15, 2009 | Fossil Metal Dress Marissa ES1512 Watch...
2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Dec 08, 2008 | Fossil University of Oklahoma LI2282 Sport...
Fossil Metal Dress Tiffany ES1510 Watch for Women Logo
117 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
