Question about Whirlpool GD5SHAX Side by Side Refrigerator
The little nozzle for the water dispenser has broken off. Can you provide the location and part no. for this? Thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Go to Whirlpool.com parts. or call the service number on the inside of the door.
Posted on Oct 10, 2010
Lg 27.7 w ice maker water dispenser has little 'water pressure slow flow on water dispensing
If your ice maker kit has a piercing nozzle you would want to change that cause they build up water deposits very quickly
Dec 15, 2010 | LG Refrigerators
My Bisell Proheat will not dispense water to the floor but it will dispense through the hand held tool.
check the little nozzle that the water sprays from and see if they are plugged if not your element chamber may need to be cleaned
Mar 02, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water will not dispense. Tried putting in a new
Make sure the hoses and water nozzle are not blocked, broken, or unhooked.
Dec 01, 2009 | Cars & Trucks
One of the water nozzles used to spry water to windshield, (the ones in the hood) get broken from a kind of pipe where the little hose fits, does somebody know how to remove this nozzle? I´m not...
It is held in from under the bonnet with two parts of the nossle wider than the hole in the bonnet. Squeeze them in with plyer's and push the nozzle up through the bonnet. The new one will just push in with your hand. Cheer's
Oct 07, 2009 | 2002 Jaguar X-Type
How do you take the ice and water distributor off the freezer door for cleaning and repair?
Without the model number for your particular fridge, I can't provide you with the exact procedure. However, there should be a small retaining screw up inside the dispensing panel.
You might have to remove the trim bezel around the dispening area, which is normally held in place with retaining clips. You might need to use a small plastic (to avoid scratching the fridge door and the trim) to pry off the bezel/trim.
Once you have exposed the dispenser(s), you can then more easily get at the retaining screws to remove them from the door. With some models, you will have to remove/disconnect the water line from the dispenser nozzle. Many are slip fit couplers and you can twist the nozzle off the line, others may require cutting of the line to remove it from the dispensing nozzle, (be sure you have enough hose line to reattach to the nozzle tip).
Once removed from the door, follow recommended cleaning instructions for plastic parts, only using warm soapy water and/or a vinegar/water mix to remove hard water deposits, etc.
Reinstall parts in reverse order and test for proper functionality.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | Whirlpool Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No espresso flows out - just water from the steam nozzle
I am sorry I cannot help but I am having the same problem with just getting sludgy grounds - what did you do to solve this problem? Thanks.
Apr 13, 2009 | Gaggia Syncrony Compact Coffee...
Whirlpool Gold Side by Side Refrigerator
sounds like the switch tabs are broken off of the switch bracket behind the dispenser front cover. you should hear a distinct click when you oush in on either lever for ice or water if not then that bracket is broken.  if you'll look on the very bottom of disp cover you will see 2 slots insert a small flat blade screw driver and pry the cover off then you'll see a white bracket with switches and wiring on it look at the black switches and most likely the little plastic posts that hold them on are broken. the bracket is inexpensive and very easy to repalace. if you have any urhter questions just ask thanks peyton...
Jan 22, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE TFX20JR Have ice but no water
you have a duel water supply valve on the back bottom of frig.,the water dispenser side might be bad,or you have a micro switch behind the water dispenser that could be bad,check both-mike
Nov 20, 2008 | Refrigerators
Whirlpool GD5SHAX Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
