Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
I'm getting error code 0200000 after it passes the systems test. My model is the mfh-1-40-rt. Is this anything to be concerned about?
  • Moultrie Expert
  • 296 Answers
020000= flash test/flash charging failed...IR array or day/night sensor.
Posted on Dec 11, 2011
I have a MFH-I-40 camera. The camera stopped taking images and is reporting Error # 20000. What is the problem?
Hi.
Moultrie error code 20000 means that your flash is not working. Moultrie will advise you to cover the day/nite sensor while running the diagnostic test.
Some people have fixed the error by removing the batteries while the camera is switched on and then reinserting them.
Regards.
Jun 08, 2011 | Moultrie Cameras
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie game cam error code 1496 ?
this can't be an error code; error codes are in the format of 000000...100000=bat.test(0=pass;1=failed);020000=flash test/charging(0=pass;2=fail);003000=IR Sensor Test(0=pass;3=fail);000400=Camera Mod Test(0=pass;4-fail);000050=Memory Test.In this digit there are several codes...(0=memory ok/no sd card;5=memory full;6=SDcard locked;7=SDcard damaged;8= comms error)last digit,000006=Clock Test(0=pass;9=fail).
Are you sure this # is not preceeded by an "E", WOULD BE # OF EVENTS SINCE THEY WERE LAST CLEARED.
Ron L.
Jan 15, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Let me know how this works out for you.
Benjamin
Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Oct 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error code 3000
IR sensor failed...if doing self test, you have to cover the sensor to "fool" cam to think it is night.
Sep 15, 2009 | Moultrie MFH-DGS-200 Digital Camera
What does error code 00400 mean
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
Aug 31, 2009 | Moultrie MFH-DGS-200 Digital Camera
Abs light blinks 16 times brake lights dont work
16 is a pass code. For some reasom your diagnostic connector is in test mode.
If light flashes, diagnostic circuit is grounded. CORRECT condition.
If anything other than Code 16, and starting with the first code recorded, GO to the pinpoint test for that code.
If Code 16, and if previous action has been taken, concern most likely has been corrected and ABS system is OK. Otherwise, GO to PC6 .
Diagnostic Data Link Connector located at the left-hand side of the engine compartment and marked ANTI-LOCK TEST.
Jun 26, 2009 | 1996 Ford F350 Crew Cab
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
182 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
