Question about Hasbro Playskool Helmet Heroes Motorbike Police Officer
The microphone does not work when in the ON position but helmet works in demo also the motorcycle controller does not do anything, I have replaced the batteries with new ones, we just pulled out of the box less than 2 hours ago and ha not worked yet
2 Suggested Answers
SOURCE: Controller not working : helmet functions perfectly
1.) make sure the helmet is switched to "ON" not "Demo"
2.) if the toy stops working, try pressing the yellow button directly above the playskool logo on the helmet.
The toy uses a simple IR light to communicate between the controller and the helmet, and any controller will work with any helmet. Make sure the light and the receiver in the helmet (front, middle under the lip in line with the playskool logo) have an unobstructed view of one another.
Hope this helps.
Posted on Nov 19, 2009
Need instructions for helmet hero race driver please!
Go here and click on Demo below the Picture of your Toy and there are links to the right, but it is kind of an interactive Demonstration of how the toy works.Click the Link SETUP to se how to setup the toy for use.
Thumbs up if helpful also Feedback is Appreciated!!
Jun 17, 2011 | Hasbro Playskool Helmet Heroes Motorbike...
I have an Optrel Satellite and the auto-darkening function has stopped working (weeks before I take my journeyman's, wouldn't you know?) It is no longer under warranty....can anything be done to fix it?
I recently learned something new about these helmets. I really like like the fit and comfort of the OPTREL helmets; best I have ever owned, but the dying, irreplaceable battery thing drives me crazy. What makes it worse is that I spent over $400 to purchase mine and it lasted only 2 years. Unfortunately, I trashed my first one, trying to replace the batteries. Don't do what I did, or at least try this first. Hopefully this will restore full functionality to your helmet.
First step is to cover the sensor ports with opaque tape. These are the little ports on the AD Cartridge, which are located below and to the inside of the photo-voltaic (PV) charging cells. Covering these ports prevents the auto-darkening function from working, while the batteries are being charged. I used masking tape which was covered with duct tape so it was both easy to remove and it completely blocked light from passing through. Next step: Prepare a charging source by placing a CFD light bulb in a utility work light fixture. Mine was an aluminum, reflective fixture with a spring clamp for holding it in position. The bulb must be at least 23W (100W equiv.) and probably not more than 50W, to prevent overheating of the helmet and AD Cartridge. There are likely other light sources which will work as well, the objective being to provide ample and constant charging energy without overheating the helmet or AD cartridge. Position the lamp about 6 inches from the PV cells, immediately in front of the helmet so that the PV cells are able to capture as much of the light energy as possible. The lens should not be darkened in this state, due to the sensors being covered. Test by placing a 3x5 card, or something similar, between the light and helmet. The lens should not darken when exposed to light. The helmet can remain in this state for as long as you like. I left mine to charge for 5 days, after which it was able to maintain the darkened state with no issues.
On occasion, I think it may be beneficial to cycle the batteries on this helmet, i.e., discharge and then recharge. This can be accomplished by placing opaque tape over the PV cells, to temporarily defeat the charging function. Place the helmet in front of the light source, similar to the arrangement described above, positioning the helmet in such a way as to trigger darkening of AD cartridge lens. Note that the sensor ports must be uncovered for the lens to darken. Darkening the lens consumes battery power so leave the helmet in this state until the lens is no longer darkened, which could take hours to days, depending upon the condition of your batteries. Test lens darkening by placing something like a 3x5 card between the light source and sensors, which will cause the lens to transition from dark to light. Once the battery is sufficiently discharged, to a point that the lens no longer able to maintain the darkened state, then recharge the batteries using the procedure described above. Do not leave the helmet with batteries discharged, as this could cause permanent damage to the batteries and AD Cartridge. Hope this works for you. Best Regards.
Oct 27, 2010 | Uvex Optrel Satellite Welding Helmet #...
Radio comes on --but speakers do not works
Check your three position switch on the dash.
One position is front speakers - one is both front and back and one is helmet only
Aug 31, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
2004 1800 GW headset stereo problem
How about the fader control, Is it all the way to the left?
Jun 06, 2009 | 2004 Honda GL 1800 Gold Wing
I have a 93 Honda Goldwing with a built in CB Radio. I have a full face helmet that I bought with a bluetooth wireless headset that connects wirelessly to my cell phone. I'd like to be able to also connect...
the dongle is just the wiring to connect a wired headset to your jack on the bike there are many aftermarket companies who have the right parts to connect your headset to your stereo and cb radio I have j&m and they work flawlessly
May 08, 2009 | 1993 Honda GL 1500 Aspencade Gold Wing
Hope this helps.
Mar 25, 2009 | Hasbro Playskool Helmet Heroes Motorbike...
Microphone,xp isn't running,mousepad (cq60-104tu)
if your system is xp and it has not been removed then
you need to uninstall the vista demo
through control panel add/remove
please let me know
Jan 30, 2009 | Compaq Presario Notebook
Garmin Zumo wired headset
I bought a wired motorcycle headset, which does works okay (below 50 mph) www.imc-motorcom.com, didn't like the wire so I switched to a BT helmet kit, manufactured by interphone, works like a charm.
May 03, 2008 | Garmin zumo 550 GPS Receiver
Hasbro Playskool Helmet Heroes Motorbike Police Officer Logo
63 people viewed this question
Top Hasbro Toys Experts
thegtw
Spidey28
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
