How to remove bearing - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101.
Posted on Oct 11, 2010
Replacing rear wheel bearing. how to remove?
Remove the rear wheel, then the bearing cap. Then remove the split pin out, the crowed washer and bearing nut & washer. Now remove the outer tapered bearing, and the brake disk ...
Aug 15, 2011 | 1997 Audi A4
Remove &replace 95 accord rear wheel bearing
remove this items in this order(rear disc):
-remove rear wheel(the side you are replace)(19mm socket)
-remove brake caliper with cailper bracket(14mm socket)
-remove brake disc
-remove metal cover hub/bearing assembly with flathead screwdriver
-remove 36mm nut behind metal cover.
-pull hub/bearing assembly out.
note:sometime the inner side of bearing stay on knuckle and you have to pry it out pry bar. check old bearing vs new bearing and you'll see the different. Don't reuse any parts of the old bearing.
-install new hub/bearing
Dec 15, 2010 | 1995 Honda Accord
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
How do you change the rear wheel bearings on a 2004 chevy express 1500 van?
Axle Shaft Bearing & Seal Removal & Installation To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the axle shaft.
  3. If replacing only the seal, remove the seal using a suitable seal removal tool.
  4. If replacing the seal and bearing on the 8.6 inch axle, install the slide hammer and adapter behind the bearing and pull out the bearing and seal together.
  5. If replacing the rear axle shaft seal and the bearing on the 9.75 inch axle, install the J 29712 or equivalent bearing puller into the axle housing behind the axle bearing.
  6. Remove the axle shaft seal and the bearing by tightening the nut on the J 29712 bearing puller.
Use a slide hammer, bearing puller and adapter to remove the old axle bearing 88457g81.gif
To Install:
  1. Install the axle shaft bearing using a suitable size driver. Drive the bearing into the housing until the tool bottoms against the tube.
  2. Lubricate the seal lip and install the seal with a suitable seal driver. Make sure the seal is fully seated in the axle tube.
  3. Install the axle shaft.
  4. Fill the rear axle with the correct lubricant.
  5. Lower the vehicle.
Oct 18, 2010 | 2004 Chevrolet Express
How to change wheel bearings on a 2004 chevy cavalier
There a bolt in bearing so they are pretty easy. Jack up the car, remove the tire/wheel, remove the caliper, remove the rotor, remove the axle nut, unplug ABS sensor if equipped, remove three bearing to knuckle bolts. remove the bearing.
Make sure you torque the axle nut to the proper spec after installing the new bearing. Failure to do so will cause the new bearing to prematurely fail. Also get a good quality bearing. The less expensive bearings are less expensive for a reason. You don't need the most expensive one but you want one from a good manufacturer.
Sep 24, 2010 | Chevrolet Cavalier Cars & Trucks
How do I change front hub and bearing assembly on 2004 Explorer
Front hub bearing, remove tire, remove caliper and caliper holding bracket, you do not have to remove brake caliper from brake hose, just set it aside, if 4X4 remove front axle nut that goes through center of rotor, also remove brake rotor, disconnect elec, A.B.S connector, remove three bolts on back side of hub bearing, remove hub bearing, some times you will need to knock hub bearing out with a hammer.Reverse to install new hub bearing.
Jul 09, 2010 | 2004 Ford Explorer
Removing bearing from rear wheel 03 ultra classic
you could use a blind hole bearing remover w/slide hammer these bearing are suppose to be tight and straight.if they are removed and installed wrong you could ruin the hub. Harley switched to sealed wheel bearings in 2000 earlier models were tappered bearings.
Apr 18, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
How to remove bearings on 1998 gmc jimmy axle shaft bearings and pinion bearing?
if diying and axle bad replace the whole unit from salvage or rebuild shop.if changing the bearings its a lot of work and you will need some special tools to put back together .first you need to use a lift or again have to remove unit from truck, disconnect battery remove drive shaft,remove pinion nut need large breaker bar loosen bolts to rear cover drain fluid remove cover have someone push axles toward center remove c locks slide out axles best way to remove bearings is slide hammer bearing removal unit remove rear [gears] dont loose shims will see pinion bearing bearing remove and replace now 2 put it back.need shim package, red lead, 4 ring and gear mesh adjustments ,,
Jul 07, 2009 | 1997 GMC Jimmy
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Need to know how to remove rear axle bearing
Remove the differential cover let fluid drain. While draining remove the tire on the side with the bad bearing. Remove the brake drum. remove the spider gears if it has a open diff. If not an open diff you will need to get a book at a parts house about $20. After removing spider gears remove the axle C-clip then pull the axle out. You will need a bearing seperator to remove the bearing. An oldschool trick for installing the new bearing with out a press is to stick the axle in a freezer for about 2 hours about 30 minutes before removing the axle put the bearing in an oven at 350 degrees (wear gloves when getting the bearing out) Quickly remove the axle and then remove the bearing and immediatly install the bearing it should drop onto the axle right where the old bearing was I like to take a puch and tat the inside of the bearing to make sure it has seated all the way.
Any questions please let me know
Have a great day
Apr 29, 2009 | 1995 GMC Jimmy
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
