Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 11, 2010
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water always leaking out from bottom of fridge
If you have a ice maker check to see if the leak is coming from where the water connects into the back of the frig. If you dont have a ice maker. Look under the frig and be sure that you have a drain pan in place.
Aug 15, 2009 | Hotpoint Refrigerators
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
Ice maker is making ice but leaking alot of water under the fridge and in the freezer. What can I do to shut if off until I repair the ice maker?
pull our your frig. and follow the water line coming into it. the other end should have a valve on it in the floor or the wall. turn off the valve and that will stop any water from coming to your frig for water or ice making.
Apr 22, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maler water leaking
Found that ice had accumulatd in the refill cup that prevented the water from filling the mold so that it spilled over into the frezzer compartment
Mar 25, 2009 | GE Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
GE Side by Side refrigerator and frezzer not cooling
FIRST MAKE SURE YOU HAVE IT SET TO DIVERT MORE AIR TO FREEZER SIDE THAN RE FRIG SIDE , MAKE SURE THERMOSTAT IS SET TO COOL ENOUGH , NEXT MAKE SURE SMALL FAN IN REAR OF FREEZER IS RUNNING , SOME MODELS YOU MUST DEPRESS DOOR SWITCH AS YOU WATCH IT , IF FAN IS BAD YOU CAN REPLACE IT YOURSELF REMOVE FAN AND COVER AND MOST UNPLUG , SOME IDEAS
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water in floor
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 26, 2008 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
143 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
