Question about Hoover Nextra HNT 2135 Top Load Washer
Final spin drum knocks and is unbalanced, never used to do this.
HEAVY DUTY 10.1KG/2SPEED GIANT CAPACITY PLUS
Contact me on allprint@wbs.co.za
  • allprint Jun 08, 2008
    Thank for your help but it stell dose it
    Regards
    Arthur
  • 38 Answers
Hello, if your clothing are sorted imbalanced you will have that problem. Ensure they are evenly distributed.
If that doesnt solve the problem, there is a bolt that is broken on the agitator shaft. Lift out the top cap from the agitator, take out the plastic seal beneath, remove the bolt, lift agitator out.
There are two horizontal bolts holding the inner-drum to the shaft. replace both.Be sure to tighten all the way.
Posted on Jun 01, 2008
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Where is the heating element on a crosley heavy duty giant capacity plus
The element will be at the back of the dryer behind the drum I will give you a link to a video that will show you how to do this .It is not a hard fix and takes 15 to 20 minutes..
Jul 04, 2012 | Crosley Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
I have a Roper Heavy Duty Large capacity washer # RAB5232EW. during every spin cycle it is unbalanced and knocks like it will jump out of the wash room. Please Help!
when empty turn it upside down it should have three springs holding the washing machine to the frame
one mabe missing if that not the prob try leveling the load and make sure the leveling leggs are all
toutching the floor good luck
Oct 17, 2011 | Roper Washing Machines
There is a knock in the dryer but not constantly
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 26, 2010 | Dryers
Little AGITATION clothes not getting clean, Spin cycle is fine
Hi Sherrie,
There is a service manual located inside the front left side of the cabinet.I find it easier to turn the washer on it's back and then reach up in the cabinet to get it.Hope this Helps !
Oct 23, 2017 | Whirlpool Washing Machines
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Hoover Nextra HNT 2135 Top Load Washer Logo
239 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
