Question about Microwave Ovens
Instructions to change a bulb in Whirlpool FT337/SL Microwave
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Have a Whirlpool RMC275PD microwave. Light bulb
If you see no removable panel inside the cavity, it will be necessary to remove the housing to replace the bulb. Because of the nature of microwave energy, the fewer sharp edges and other irregularities in the cavity, the happier the magnetron is since all those have some effect on the distribution of the energy and efficiency of the unit. That's why one should avoid having any larger metallic container in a microwave. Using aluminum foil to prevent the drying out of certain types of foods is permissible because the ratio between moisture content of the food and the reflection of energy caused by the foil is not significant and the energy is mostly absorbed instead of reflected.
Posted on Oct 31, 2009
I have a whirlpool combination microwave with oven. How do I change the bulb in the microwave?
Whirlpool Microwave Bulb Replacment - YouTube
? 4:35
https://www.youtube.com/watch?v=RQM302PShKw
Oct 29, 2011 - Uploaded by Dan Jiles
I show how to access the bulb on a Whirlpool Microwave that shines on your cook top, as well as how to access and replacethe bulb that is for the microwave ... ... How to disassemblemicrowave oven. Find info: fuse, bulb, fan ..
Nov 07, 2015 | Whirlpool Microwave Ovens
How do you change the bulb
Light bulb on whirlpool FT339/SL HOW TO CHANGE
Oct 08, 2014 | Whirlpool FT 339 Black Microwave
Change light bulb microwave
If your owner's manual doesn't cover it, then you will have to do some disassembly, and may have to remove the oven from the wall, depending on the model number, which you did not mention.
But since you posted this is the Whirlpool microwave section, I'll assume that's it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 17, 2013 | Whirlpool GH5176XPT microwave Oven
How do i replace the bulb for the under light
The owner's manual covers that.
It depends on your brand and model, which you did not mention.
You can download GE owner's manuals and installation instructions here.
Apr 14, 2013 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
How do you change the bulb in a Kitchenaid microwave Model KBMC140HSS03
Hello & Welcome to FixYa
To replace the light bulb first remove the screws located on the vent grill at the top of the microwave, tilt the grill back and then pull away to remove. After this open the light cover , you have to remove the screws so that you can discard the old light bulb and then replace it with a new one. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
I need to replace light bulb in Whirlpool built in microwave model # RMC 275PD. Is it necessary to remove unit from wall to replace the light bulb?
It looks like it, but if you look at the diagrams, maybe not.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Oct 02, 2010 | Whirlpool RMC275PD Microwave Oven
Replace light bulb on Whirlpool GMC305PDS07 Microwave oven without a $150 service call. (The bulb does not unscrew from inside the oven.)
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 03, 2009 | Whirlpool GH7145XF Microwave Oven
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
