Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
I keep getting error 20 about the last 25 minutes and it won't spin
    President:
  • 1,554 Answers
Water is not draining as indicated by error code 20 and therefore the machine cannot advance to the spin cycle. Either the drain hose is clogged/kinked, the pump is blocked or not working, or the trap is blocked.
Check to make sure the drain hose is not clogged/kinked then access the pump assembly and check the pump including the trap. The front panel needs to be removed to access the pump assembly which will require the removal of the top panel, console, door gasket, and the door lock and switch assembly. Once the front panel is off, remove the pump outlet hose from the pump and the tub-to-pump hose from the tub. The trap is located in the tub-to-pump hose. Take the pump assembly out after the pump securing screws are removed then clean the trap and inspect the pump for any sign of damage.
Posted on Oct 10, 2010
LG tromm washer is stuck at 22 minutes and just keeps washing and spinning
Sometimes the firmware or program in the microcontroller of the machine gets scrambled due to electrical spikes or fluorescent lamp frequencies in the vicinity of the machine.
Unplug the mains supply for about 10 to 20 minutes and retry, this will normally solve the problem as the firmware program resets itself.
Dec 14, 2015 | LG Washing Machines
I go to the store. Turn truck off. Go inside and come back outside and the truck won't start. Wait about 20 minutes and truck starts right up. This has happend 3 times in the last week. This morni
usually this is a cam position sensor I have found this problem many times by replaceing the camshaft position sensor I believe this will solve your problem if this is helpful please leave good feedback
Apr 13, 2013 | Ford F-150 Cars & Trucks
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
My toyota avalon starup to fast
have the idle speed sensor checked as well as the air temp sensor. Possible showing up as errors in the code
Jan 12, 2013 | Cars & Trucks
When my washer gets to the spin/drain cycle (the last 20 minutes) it cuts off and unlocks. The machine keeps locking and unlocking and that's it. It will not move to the spin/drain cycle. What is the...
The filter on the front side of the washer was clogged. I have two children. So, I found candy wrappers, lip gloss, pennies. After cleaning the filter, it runs fine now.
Dec 17, 2009 | General Electric WCVH6800J Front Load...
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
