Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
How do you change the spool? - Black & Decker 14" Grass Hog Xp Trimmer/Edger
    President:
  • Black & Decker Master
  • 1,545 Answers
See the second page of the Grass Hog user manual here. Adobe reader is needed to view this.
http://www.blackanddeckerservicenet.com/documents/English/Instruction%20Manual/90524916,GH700%20GH750.pdf
Posted on Oct 10, 2010
How to change my spool pin
Some spool pins pull out, others have skrew threads on the bottom, yet others need to have the spool casing removed. Depends on your sewing machine.
Search the internet for:
Make + Model + the word "spool pin"
or contact manufacturer support.
Apr 21, 2016 | Brother Sewing Machines
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
I have a Simplicity Embrodery Machine, and the needle keeps breaking. I have checked the bobbin, changed the bobbin, changed the thread, changed the pattern. It sews for about 5 seconds and then breaks.
It could be the thread is hanging up and breaking the needle.
Check the thread spool for nicks - turn the spool so the thread is feeding from the bottom of the spool.
Watch the thread as the machine stitches, if the thread is pooling at the base of the spool, use a thread net on the spool.
Open the needle plate and remove the bobbin and bobbin case - clean out any lint or thread snips that may have accumulated there - do this often to help the machine work as it should.
Feb 19, 2010 | Simplicity Sewing Machines
How do you change the cord on a b and d strimmer
Hi, W/D here.
Pull the spool straight off, out of the head. Look at the bottom of the spool, you'll see arrows indicating the direction that the line should be wound. Now, look at the spool. You'll see that there are actually two spools, made together. In the middle part of each spool, you'll see a small hole. There should also be a notch in between the two spools.
OK. Starting with the inner spool, insert your line into the hole about 1/8", and wind in the direction of the arrows. When you have wound the line to the diameter of the divider between the spools, stop. There is a very small notch on the bottom of the spools that is 180 degrees from the notch in between the spools, and at the bottom edge of the spool that you are winding. Click your line into that notch. Leave about 6" of line out past the notch, and cut it off from the pack of line that you are winding from. Now, wind the outer spool the same way. When full, you'll guide your line thru the notch between the spools and into the small notch at the bottom of the inner spool. Leave another 6" tail, and cut it off.
Take the two tails of line while holding the spool,and insert one into each grommet on the machine head. Align the line notches with the grommets, and press the spool into place. You should feel it click into place. Now, you want to tug on the line tails to pull them out of the notches. You're done!
I have one final bit of advice, and you don't have to do it this time...just keep it in mind... The head will sometimes be stubborn in dispensing the line. I find that occasionally putting a little graphite into the hole where tha spool fits onto the machine helps the line advance part work much smoother, and it keeps the head from sticking.
Best regards, --W/D--
Aug 14, 2009 | Black & Decker Garden
HP2420dn printer spools SLOOOOOWLY
try to change spool settings
Control Panel-Printer Properties-Advanced Tab
Select Spool Print Documents-Start printing after last page is spooled.
Aug 11, 2009 | HP LaserJet 2420 Printer
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
816 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
