Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Motor runs but will not pump - Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
    President:
  • Aqua Flo Master
  • 1,378 Answers
Remove the unit and open up the pump end and inspect the impeller for blockage or perhaps it is broken; clear or replace as needed. You should also replace the pump seal at the same time. If these seem beyond your ability a local electric motor repair shop should be able to do this for you for less than $60.
John
Posted on Oct 11, 2010
Baptistry pump not working
make sure you are getting voltage to the pump motor by checking with a voltmeter. If the motor is getting power but not running I would think the motor is the issue. If the motor is running but the pump is not pumping I would think the problem is either the coupler that connects the pump to the motor, or the pump itself.
Aug 23, 2014 | Cars & Trucks
Flotec pump 1hp motor has become too noisy when running
Is it the pump or motor. Pumps do wear out and need rebuilding or replacement.
Dec 17, 2013 | Plumbing
Pool pump not pumping
A few things to look at-
  • Did you fill the pump pot with water?
  • Check to make sure that the pot lid o-ring is in place.
  • Verify that your plumbing is sound and has no suction leak.
  • Check water level in pool.
  • Make sure the voltage is correct. Many pumps come pre-wired for 220v. If you have 110v supplying the motor it will run at half speed. There is a diagram on the side of the motor showing how to convert to 110V. Make sure that your supply is 110v before converting the motor. If you switch the motor to run on 110v and hook it up to 220v it will ruin the motor instantly.
Feb 19, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Pump makes buzzing noise but does not run. shortly thereafter it trips circuit breaker.
The first thing to check is if the pump is siezed up and stopping the motor or if the motor is bad....
Take the motor off of the pump and check to see if the pump will spin... then check if the motor will run without the pump onit...
This will tell you if you have a bad motor or a bad pump...
heatman101
Feb 21, 2011 | AO Smith Centurion 1081 2 Hp Standard...
Pump will not stay running. motor gets warm. motor shuts down after running for about 10 to 20 seconds.
Check the voltage at the pump while its running. If the electric feed line is too long for the guage wire,
voltage drop will cause the motor to overheat and switch off.
Oct 07, 2010 | Flotec Corrosion Resistant Shallow Well...
1 HP StaRite Pump 15" inout Center Discharge 240V wHair Lint Pot: Impellers on pump wont turn. Motor not running...
what happens is the pump gets staved for water and this damages the shaft seal, water slowly over time leaks into the motor and pollutes the grease int the bearing and causes it to fail. it's fairly easy fix, just have the motor rebuilt by your local pool pump motor repair guy for about 75.00 and your back up and running. beats paying 200.00 or more for a new motor.
the sta rite is the top of the line pump, i have had them in my shop over 40 years old ! ask your motor repair guy how to get the most life out of your pump. knowledge is king .. remember to prime the pump after any pump repair !! .. jay longwood florida
May 17, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
LG front load washer does not drain after cycle. Motor runs,drum moves forward and reverse but seems pump doesn't pump. Drain hose clear as well as filter area.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
I removed my pump because water would not drain. i plugged up and pump still does not move, but winding sound is present. Does the motor require a load to run? And does this mean the pump is bad?
Hi, water pump doesn't require load to run, check motor (coi)l with ohm meter (multi-tester), check for continuity, good job, removing pump and cleaning it, it's a commom problem with washing machine. it's possible your pump motor burnt out, two things you can do, to check pump, (1) two wires that you remove from pump motor, put volt meter,put power to machine, be careful, check for correct voltage, if voltage is present, and pump didn't work, then water pump motor, burnt out (2) remove water pump, make extension cord, plug directly to receptacle, if it's good, it will run, if it didn't run, replace it, good luck
Aug 08, 2009 | Whirlpool LSR6332K Top Load Washer
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
179 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
