Question about Microwave Ovens
DELONGHI MICROWAVE MANUAL EM821AAN-X2 - Microwave Ovens
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: DeLonghi microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 09, 2009
sonicboomele
  • 1557 Answers
SOURCE: my delonghi em821aan-x2 works without making food
in most cases the magnatron has gone bad as they are very expensive in most cases we write them off . sorry i think its time for a new microwave
best wishes
sonic boom electronics
Posted on Nov 06, 2010
I need a for Manual for microwave delonghi p80d20el
DeLonghi may be able to supply the manual you need.
Oct 11, 2013 | DeLonghi Microwave Ovens
DELONGHI MICROWAVE EMB821AAN USER MANUAL
You should be able to find help at the DeLonghi customer service site.
Oct 27, 2011 | DeLonghi MW 605 Convection/Microwave Oven
My delonghi em821aan-x2 works without making food hot
best wishes
Nov 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
I require ain instruction manual for a delonghi mw865f microwave
just open the link and enter the code given and download the manual
http://www.givemefile.net/manuals/_microwave_ovens/delonghi/file/27939.html
Apr 18, 2010 | DeLonghi Microwave Ovens
My delonghi microwave mm821aan-x2 is not heating. the turnstable is working and the light too....is it a part i need to make it work?
Could be several things. Fuse blown to the magnetron circuit. Bad magnetron or fuse and HV diode blown to magnetron circuit. The fuses are only about $5 at www.mcmelectronic.com . If the unit is extremely old the magnetron could be bad but generally it is the fuse and HV diode. For the cost of the parts it would certainly be worth fixing if you have the ability. Let me know how it works out.
hardrocko
Feb 10, 2010 | DeLonghi Microwave Ovens
Delonghi EM821AAN-800watt The turn table has stopped spinning
Make sure the turntable guide is lined up properly and there is no debris caught in it. Examine the turn table bushing the tray sits on and make sure it is not worn or broken. Make sure the turntable is sitting down in the groove correctly. Lastly it may be the drive motor itself is bad. This is the small motor that turns the carousel. This motor is very difficult to replace and unless you are qualified you should not attempt this repair and leave it to a professional. This motor will cost from $40 to $75 plus the cost of having it replaced. You may want to consider buying a new microwave if this unit is over 5 years old. You could end up spending more to repair this one than a new one costs. Of course you can use it without the carousel.
Dec 02, 2009 | DeLonghi MW 605 Convection/Microwave Oven
Jan 07, 2009 | Microwave Ovens
Microwave Ovens Logo
862 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
