Question about Samsung BlackJack Smartphone
Keyboard lights seems my blackjacks keyboard will only light up when i type. before it would stay luminated for a few seconds then turn off. now it turns off right away
  • pamy1216 Jan 27, 2009
    half of my keyboard does not light up. Any suggestions???
My back light just gave out on me entirely...
Posted on Jun 16, 2008
Well i don't have something to say
Posted on May 31, 2008
Hp pavilion dv4 black screen
have some experience as a technician, able to replace the keyboard and palm rest of your laptop.
if it is not able to look for someone who will be able to do
Jan 27, 2014 | Computers & Internet
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
Lows don't work at all highs work 1/2 way switch works normal
not sure here to be truthful but i seem to think you could have a problem in the light switch
Mar 12, 2010 | 2006 Dodge Stratus
Maintence light is blinkin when i start my car
Generally, the maintenance light should come on for a few seconds, then go off after the car has started. All of the dashboard warning lights do this so driver can tell they are operational. (Should see brake light, low oil pressure, airbag warning, etc. Any of the lowly "idiot" lights should come on.)
As a test, turn the key on, but not to start. All of the lights should flash on for a few seconds, sometimes in sequence, then go out. Now, sart the car, some lights may come on and back off. If none stay on after a few seconds of engine running, you are probably ok.
Sep 23, 2009 | 2000 Honda Accord
Dell 17" monitor is not turning on.
1. Check the cable with the blue connector. Make sure it's plugged well to the back of the computer.
2. CHeck the light on the CPU's power button. If it's solid green, press the numlock key on the keyboard. Tell me, if the numlock light on the keyboard turned off or on. You can press it again if you didnt catch anything.
3. If there are no lights on the keyboard or the computer when you turn it on, the computer is the problem.
Just post here what lights are present or what happens when you press the numlock key.
Jun 16, 2009 | Dell P793 17" CRT Monitor
Noka N95 8gb keeps turning off and not restarting
ba83ee5.jpghello,you do not try master reset *#7780# or *#7370#
please remove your mm c card and switch off your mobile and 5 minute after you try without you mm c card; then no solution so, you are watch nokia care
Apr 20, 2009 | Nokia N95 Cellular Phone
How is a flashlight both luminous and nonluminous at the same time?
At first light it DOES sound a bit confusing.
First, the definition of the term 'NON-LUMINOUS'; 'Not capable of PRODUCING light but can be capable of REFLECTING light from another source'.
For instance, our MOON is NON-LUMINOUS as it REFLECTS light from the Sun. The SUN is LUMINOUS as it produces light that is REFLECTED off the surface of the moon. And so, LUMINOUS means capable of PRODUCING light.
Now closely examine your flashlight.
The BATTERIES produce electrical energy which is transferred to the BULB which emits light, thus LUMINOUS. The tiny little BULB emits quite a lot of light for its small size. However, the bulb is contained within a concave silvered cone which REFLECTS,(NON-LUMINOUS) gathers and channels the emitted light from the BULB (LUMINOUS) into a BEAM which ILLUMINATES whatever you are pointing the flashlight at.
Our cameras would be just paperweights if there were no NON-LUMINOUS surfaces for the light to REFLECT off of, back into the camera lens, onto the 'plate' thus etching the image. For example, take a photograph in the dark without the flash and what do you get. No LUMINOUS, no NON-LUMINOUS.
And so there we have LUMINOUS and NON-LUMINOUS, ILLUMINATING our lives. Enjoy! :)
Jul 21, 2008 | Vector Power On Board High Intensity...
Backlight of LCD turns off
For latitude systems they have this ambient light sensor. it basically adjusts the brightness of the screen depening on room lighting. try to go to bios by hitting F2 on the dell logo. go to video and try to look for ambient light sensor. however, im not sure if your computer has that feature I have a second option for you though. based on the troubleshooting you've done, it seems that the video back lighting is affected by movement. it would be a good try to reseat the LCD cable. you can use this link to guide you in fixing the computer : http://support.dell.com/support/edocs/systems/latd505/sm/keyboard.htm
all you need to do is to take out the keyboard with 2 screw holding it in place. the LCD cable should then be accessible. it a thick cable that coming out of the Left hinge.
Hope this helps.
thanks.
Dec 24, 2007 | Dell Latitude D505 Notebook
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
H350 pairing with Blackjack
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Sep 14, 2007 | Motorola Mobility H350 Wireless Headset
Samsung BlackJack Smartphone Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
