Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Paper won't feed through paper tray - screaming clicking noise, then LCD reads load paper cassette
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
SOURCE: canon MX850 - paper feed
Look carefully because it is a cassette on the bottom of your canon mx850... so the solution is: or you fill that cassette or you switch your canon (it is a button for that) to take the paper from the top...
Posted on Feb 15, 2010
SOURCE: bottom tray won't feed paper
adjust the left, right and rear paper guides so that the paper isn't fitting into the tray so tight. The clicking sound you hear is the gear trying to raise the paper to be fed, but it can't do it's job because the paper is in so tight. On mine, the culprit was the rear guide so I let it out just 1/4" or so-just enough to give the paper a little more room to move-problem solved-for me at least!!
Posted on Mar 26, 2010
MY Epson WF-3520 will not print from the rear paper feed.
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Apr 06, 2015 | Epson WorkForce Office Equipment &...
Kyocera not feeding paper.
Open paper tray, locate the feed roller (small rubbery wheel) and moisten a cloth. Gently clean the roller to remove build up of paper dust from it.
Also worth using is some "anti static foam cleanser" on the cloth to help deep clean the rollers, or the pre-moistened "Screen wipes"
Also check there is nothing blocking hte paper path, remove paper cassette, and toner catridge (and drum if I recall correctly) and see if you can feed a sheet of paper MANUALLY from tray up into the "imaging chamber" where the toner lives. If this feels too stiff, there could be an obstruction in the way, fragment of paper scrunched up after a REAL jam, or fault sensor arm.
If you find something and can remove it, reassemble, and test
Dec 10, 2014 | Kyocera FS-4000DN Laser Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
Cassette not lifting making noises.
If the paper is in the paper tray correctly, you can try to remove the affected cassette. Look inside for a wade of paper blocking the paper present sensor. If so remove the jammed paper. If that is not the case, you will have to have the lift gear replaced in the paper feed unit. It is a Black half moon gear... It is not easy to replace..... Mostly, it is the top paper tay. If you can't afford to have the work done? I would not use the tray & change one of the other trays to the paper tray..... Good Luck
May 29, 2010 | Canon imageRUNNER 400S Copier
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
FRONT PAPER FEED
Go to this site. In the search window in the center of the screen, type "paper tray" and click on the Search button. Select the link "How do I load the paper". When the document comes up, select the link "Cassette" near the top. You will see illustrated step-by-step instructions. If you are missing the cassette tray, contact Canon.
Feb 05, 2009 | Canon PIXMA MX850 Multifunction Printer
Mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Aug 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
66 people viewed this question
old marine
old marine
