Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Out of range box on my screen - ViewSonic VA720 17" LCD Flat Panel Monitor
  • 11,361 Answers
Your PC video resoliton is set too high for the monitor to display, it shoulde be set to the native resoltion of this monitor: 1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.viewsonic.com.au/product_pdfs/lcd/17/E-VA720-10142003.pdf
Unless the monitor has the problem inside:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Posted on Oct 10, 2010
My frontech lcd tv box model no.jil 0622 is display d-sub out of range 55.9khz/59hz
Your computer is showing a resolution that the screen does not support. Look up the optimal resolution of the screen online , boot the PC to safe mode then select the correct resolution in display settings
Sep 27, 2017 | BOX Computers & Internet
How to fix out of range problem on sony bravia with pc
Well I just changed the resolution settings in my android box to 720 from 1080p > plugged it in and my box now works...simples.
Jan 29, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
How to set port forwarding?
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. By default the IP address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router.
Click the Firewall button near the top of the page. Use the Protocol drop down box to select the protocol type of the ports you are forwarding. If you are forwarding a single port, enter that port number into the LAN port range, Left WAN port range and the Right WAN port range boxes. If you are forwarding a range of ports, enter the lowest number of that range into the LAN port range, Left WAN port range box. Then enter the highest number of that range into the Right WAN port range box. Enter the IP address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box. When you are finished, click the Add button.
When you're finished, click Save near the bottom of the screen to save your changes.
And that's it! You're done! Hope this helps.
Dec 22, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Getting out of range on my ViewSonic Monitor
try to check the memory. sure its on the board.
May 05, 2009 | Computers & Internet
I have a problem with my hp 1702 please help!!!!
this means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Aug 11, 2008 | HP L1702 17" LCD Monitor
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Out of range
If there is no hardware issue, this message indicates that your PC's Screen resolution settings (and/or Refresh Rate) are above the capability of the monitor. This can be corrected by booting into Safe Mode (F8) and lowering as necessary.
Good luck and kind regards.
Feb 05, 2008 | Gateway FPD2275W LCD Monitor
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Out of Range message on monitor after T5300 finished booting. No Image.
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
Jan 31, 2007 | HP T5300 (dc643a#abu) Network Terminal
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
