Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
The oven will not turn on. It reads F 30 ERR. How do I reset?
  • 2,382 Answers
Hi, the F-30 failure code states that you have a bad temp probe in the oven. You can see the probe in the oven in the top left or right corner. It is pencil sized and about 5 inches long. You would need to get to the back of the oven to replace it. It has two 1/4 in screws that hold it in place. You then plug it into the control board and you are ready for baking again. If you need one please let me know, I have pleanty in stock. The probe is $46.99 and that includes shipping to you.
Posted on Oct 11, 2010
Err code on kenmore pro model 42003
you sold it so the buyer has the problem
tell him to get in an technician to advise on the fix and the cost.
Why I say this is simple ---you have no idea how it was installed or what the buyer did after he bought it so you are not responsible for the problem
Jan 17, 2016 | Kenmore 30" Double Electric Wall Oven 4200
What does err F1 mean?
Hello - Typically error code F1 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
May 03, 2012 | GE Profile JTP56 Electric Double Oven
What to do by Err 23
Hi, i had the same problem. I called Electrolux and they said it is a mis-communication between the panel and the timer. You have to turn off the power (throw the breaker) to the oven and leave it off for one minute. When you turn the power back on the oven should reset itself. If you can't turn the oven on then a service call is needed. My oven came on and I was able to use it after that.
Take care
May 13, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Kitchenaid Superba walloven/microwave - problem with big oven.
I lost power and had the same problem. 177 degrees and ERR whenever I tried to change it. Reading the manual, I noticed that it was showing the degree symbol instead of F. When you hold down the broil/maxi/econo button for five seconds, it changes to F and then it worked perfectly. Makes no sense, but worked without any repairs needed.
May 12, 2010 | KitchenAid Ovens
I tried to auto clean bottom oven. Showed err
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 05, 2010 | KitchenAid KEBC208 Electric Double Oven
The oven warms up and then starts beeping and flashes f10 err.
The "F10" oven error code means "Runaway temperature".
If you have technical skills, you can try to diagnose and repair yourself, otherwise, call a qualified appliance repairman.
Locate the temperature probe wire plug at the Electronic Oven Control (EOC) and measure its resistance. It’s supposed to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the oven temperature probe.
If the reading is correct, replace the EOC.
Jan 28, 2010 | Kenmore Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
57 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
