Question about RCA Pearl TH1102 MP3 Player
Hey i have an rca th1702-a and the audio wont work unless ihold the headphone jack just right, and even then only through one earphone. i've tried different headphones, and it doesnt seem to be damaged. any idea what the problem is or how to fix it?
    Novelist:
  • 111 Answers
The headphone has come un soldered and it is not making a contact with the motherboard .... I have this player. It did the same thing. I took it apart and found this to be the reason for mine not working. I do not have a soldering gun or else I would re solder it back to the motherboard. I would suggest asking if anyone you know would be willing to solder it back for you.
Posted on Mar 27, 2011
A model TC-P42x60 and I need to use earphones. I have tried the audio outlets using a rca cord with a 3.5mm plugged into a set of earphones, that does not work.
There are no audio outs on your TV The digital audio out is an optical output meant for a sound bar or a stereo audio amplifier that has an optical input. If you have a compatible stereo system you can use an optic cable to connect the two and then use the headphone jack on the stereo system.
Aug 05, 2017 | RCA Audio Players & Recorders
Audio jack not working for my earphones?
I would try another set of headphones and see if it works. Try changing the volume level and see if that helps. You could also try a set of powered computer speakers to test the jack. The audio jack may not output enough power for your headphones. There is also a chance the audio jack could be defective.
Oct 26, 2016 | Televison & Video
Left earphone broken
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPhone with another set of headphones or speakers just to make sure that the problem is with the iPhone.
Bad audio jack
The most likely cause of audio output problems on iPhone 4S is a bad audio-out jack. If you have determined that the problem does not lie in your external speakers, you should replace the headphone jack.
please follow the steps and fix it.
God bless you
May 28, 2013 | Cell Phones
Problems with headphone jack
Replace the headphone socket of the TV. It has contact fault.
Jul 12, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
I'm not getting any sound out of the speakers. I have sound through my headphones but cann't get anything out of any speakers.
If you can hear the sound from the headphone(earphone jack), the fault is between the headphone itself or the speakers. Check the continuity of the speakers(voice coil) using the multimeter to determine if it is faulty or not.
If you've confirmed that the speakers are not the issue here, you may spray an electrical contact cleaner to the earphone jack of your unit while pulling and inserting the headset plug to clean the contact from dirt build-up inside. You may also replace the earphone jack with new one to back the unit in normal operation.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 18, 2011 | Teac AG-V8060 Receiver
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
I'm trying to connect my mac to our lg tv. Visuals are fine, but the audio is not working. I'm using one of those belkin cables that has a white and red ouputs on one end and one for the headphone jack....
maybe the earphone plug on the MAC is not functional ...so try the one in the back ...the one for the speakers....if it is still not working ...just use a separate cable for the audio cause in this case the cable is not ok ...and just use a cable that has a 3.5 jack on one end to get signal from the audio output (no important is from headphones or the rear output) ..and in the other end to have a RCA plug just like the one fro audio ..
Here is an example for what kinda cable you need...(if you have some old cables you can make one by attaching a Jack 3.5 to an old RCA cable ..
http://www.amazon.co.uk/Belkin-3-5mm-Jack-Cable-White/dp/B0002AFT7M
Only that if you have only one RCA input on tv ..you only need a mono rca ..
Oct 23, 2010 | Computers & Internet
How to connect my wireless headphone to a Panasonic LCD TV, there is only a single earphone jack mine has got 2 plugs
That's a new one, 2 plugs would indicate seperate audio ( right and left ) or 4 . Try this go to RadioShack and buy a Y that you can plug both plugs into and then plug the single plug into the TV jack. Look at the plugs on the headphone sender do the plugs have a single band or double? If single use above solution, if double just plug 1 plug in.Good Luck.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
EarPhones
several ways.....Wirless headphones that have a small transmitter that you attached to RCA jacks coming out of audio of VCR. You can walk around or sit as far away as you need.
2nd. CONVERTER:: A RCA male plug [ again you conect to back of VCR audio plug] to audio [female] jack [you connect earphones]
Dec 07, 2007 | Sanyo VWM-900 VHS VCR
RCA Pearl TH1102 MP3 Player Logo
121 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
