Question about Honda Garden
I started the motor and it ran about 30 seconds and it cut off . I then tried to pull start it and it would not pull easy it pulled hard til i could not pull it anymore.
  • 30 Answers
I get this question a lot, and 9 times out of 10 the reason it because there is pressure in the pump. After the unit shut down did you pull the trigger to release all the pressure from the pump before attempting to restart? When these units have pressure in the pump they are near impossible to pull start.
Posted on Oct 11, 2010
My homelite mp88 chop saw is hard to turn to start
Sounds like the engine may have failed or the cylinder is liquid locked.
Feb 13, 2017 | Homelite Garden
When pulling cord to start it pulls hard take plug off its easy can't get it to start
Sounds like it seized or is starting to. I would put a little two stroke oil in the cylinder about 20cc maybe a little bite more 50cc if it is really hard to pull.... Leave The plug out and pull on it about 30 seconds hopefully when the plug is back in it will run... goodluck. If its really tight needs to be rebuilt....
Aug 10, 2014 | Garden
Hard to start weed eater
check for proper starter proceedure.some models are very specific to starting proceedure.if the equipment does not run to warm up or if the chike sequence is improper it will not start
Sep 09, 2012 | Stihl FS 85 Weed Eater
When I try to start my gas-powered pressure washer, its very hard to pull the crank and I cannot start the motor.
When everything is working correctly, and your washer has an easy start valve, (easy start valve will allow you to start the machine with-out having to hold open the trigger) the engine should pull easily. Some washers do not have easy start and you must hold open the trigger on the wand to unload the pressure in the pump. If you are holding open the valve and still have difficulty, remove the water supply and pressure hose and let out all the water. If still hard to pull most likely something has failed or pump is low/out or lubricant. If lubricant is ok, try reducing the pressure adjustment to minimun and try starting. If it is now easy to pull, problem is related to pressure regulator /unloader valve. Try adding oil to water inlet and let the oil displace out all the water within the pump and let it set for a while. Good luck
Jun 17, 2011 | Garden
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Have a snapper mower.son put 2 cycle mixed fuel in it and ran it for about 5 minutes. Now wont start. Drained and replaced fuel and changed plug. What next?
the gas sitting in the carb is "still" 2-stroke...there's a bolt on the bottom of the carb...DON"T remove it, just loosen it til the gas leaks out (about 30 seconds or so)...that is letting the 2-stroke gas out and letting in the right gas...make sure the bolt is snug..NOT TIGHT...and giver a few pulls...no choking is needed since it's already flooded from pulling on it...it'll smoke a bit and run a little rough, until it burns the oil mix residue out of the muffler...Now get a Sharpie & mark the cans... 8^)
Jun 02, 2010 | Garden
Yamaha 6600de generator dies 3 seconds after starting
When you pull the bowl off of your carb is it clean? If not you have some contamination possibly inside. You might want to remove the carb and blow compressed air through all the vents a ports.
Sep 24, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
Pumped up bulb, never does get firm, engine will run 30 seconds
You need a firm bulb. There is a checkball in the gas coupler. There should also be a float valve in the carburetor. If you have a friend with the same brand of motor (or a boat shop) it is easy to attach your tank to a different motor. If your tank will now give you a firm bulb, the floatvalve in your motor is bad.
If the bulb will not get firm with the test motor its your line. They are not expensive <$20.
Aug 12, 2009 | Boating
Overheating
CHECK THE FAN FUSE AND RELAY. IF THIS DOESNT WORK TRY CHECKING THE ELECTRIC FAN MOTOR HOPE THIS WORKS FOR YOU. GOOD LUCK
May 01, 2009 | 2006 Nissan Sentra
Garden Logo
561 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
