Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Replacing door gasket
How to fit new door gasket
  • Anonymous May 31, 2008
    How do I replase the below
  • bjmvh9 May 11, 2010
    Dutchman, easier said then done. I cannot get the gasket back on my WM1814CW LG Tromm. I have been at it for multiple hours the past two days. Any advice on getting the bugger back on? I can't even get it to the point that the retainer ring can be set. I've doule checked it's the right gasket.
    Thanks
  • 487 Answers
Depends on which machine you have but essential it is all the same. There will be a ring on the outside of the seal( outside of the machine) take that off and fold the seal ove into itself. Or even fold it into the drum. Than you can reach the retainer ring on the outside of the drum. remove that one and replace in the opposit sequence.
Aint to hard but just a little annoying to do.
Good luck
Posted on Jun 01, 2008
3 Suggested Answers
SOURCE: How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Posted on Sep 15, 2007
beltronic205
  • 1474 Answers
SOURCE: How do I fit the door gasket
The door boot seal is secured both inside and out side drums.....1st you remove securing ring on the case then the other on inner drum, if its a hotpoint model then remove front panel firstly,if not you should be able to do with mahine switched off/ unplugged and lid removed.. it can be a wee bit trickey.
Posted on Mar 31, 2010
Can gasket for CR09FFW be replaced?
if you are referring to the door seal ( sometimes called a gasket) yes it can be replaced by a new genuine item or in some areas there is a private operation that goes around making door seals to fit and are fitted as part of the price
look in the yellow pages (business directory ) for refrigerator repairs or refrigerator door seals
Note here - although you may contemplate doing the job your self , some old seals are glued in and need knowledge as how to remove it , and the door will some times go out of shape when the door shelves panel is removed so it is best to get in a professional to do the job
Nov 11, 2015 | Crosley Refrigerators
How to repair a lg dryer dlex3470v
See the groove on the edge where the gasket fits onto the door? As you peel away the gasket, you'll see how you need to thread the gasket onto the door flange so that the gasket will fit properly.
Use a silicone-based spray on lube to help it slide back on. Start at the top & work your way around the edge pressing the gasket groove onto the metal as you go. You might not even need a new gasket unless it is damaged.
Aug 14, 2014 | Dryers
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
WHAT IS THE PROCESS IN REPLACING THE GASKET ON MY KENMORE UPRIGHT FREEZER
If it is a push fit gasket it simply pulls out and the new one pushes in to the groove. Warm in hot water before fitting to ease it in. If the seal is part of the door, you have to replace the door as a complete assembly. Rare models have doors that can be taken apart and reassembled with a new gasket fitted but i don't think Kenmore is one of those.
Apr 19, 2012 | Kenmore Freezers
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
The door gasket is ripped. How do I replace it.
first - it best to get the replacement gasket and make sure it the correct one . ck the color and the size . then i remove the top half of old one ( loosen the screws and pull out of retainer then install tthe new ( top half first ) and then remove the old one completly and instal the new on . some times you will have to adjust door to fit . so do not tighten all screws tight so you can rack the door to fit and then tighten all of them mm hope this helps mm
Oct 31, 2010 | Refrigerators
The small rubber strip on the bottom inside of the front door (attached to the door) has corroded and water is pouring out during the first cycle is slimy and filthy. Is it replaceable?
It is time to change the sealing gasket and you must get a rreplacement from the Electrolux service dealer so as to change. there are also many types of this gasket suiting the origianl which can be found in hardware shops that can be fitted on to the door.Take a sample along.
Use a good brush , clean with some kerosene/diesel then use jet of water/detergent to clean the gasket, the gasket fitting slots before the new ones are fitted.
Hope this helps.
Aug 21, 2010 | Electrolux Dishwashers
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    How do I replace the door seal on a Neff under the counter refrigerstor?
    Some door seal gaskets just wedge into place and are easily replaced. Replacing the gasket is simply the reverse of removing the old one. You peal out the old gasket and fit in the new and press it into the slot.
    Jul 11, 2008 | Neff Refrigerators
    Washing Machines Logo
    310 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
