Question about Sewing Machines
Bobbin thread issue on new machine
I have a brand new Brother ns-10. I have threaded upper thread correctly (tried about 12 times) and redone the bobbin 100 times more. When i am sewing a straight stitch the top stitch is perfect but the bottom (bobbin thread) is almost a zigzag stitch rather than straight. I have adjusted all tensions but to no avail. I was hemming up soft denim jeans using the correct thread and a 90/14 schmetz brand needle which is brand new. Can anyone suggest what the problem might be. This is a machine that i have had for 5 days and i cant get the thing to sew right.
  • wildlilly May 31, 2008
    Hi thanks for the quick reply. I have it set on straight stitch number 2 (number 1 sets the needle to sew at the left) number 2 setting sets it to sew in the middle. When set on number 2 you can not adjust the stitch width as it is set by default on 0. I think i will do a few samples and take it back to my Spotlight store (got machine from them) and show them. Im hoping they can then get a Brother Rep to come show me whats happening......Thanks again for the quick reply. Im glad i found this website and will be back often..........Thanks again
  • Sewing Machines Master
  • 1,388 Answers
Have you got the stitch width selector on zero ? If not, it may be wanting to sew a small zig zag........if that is OK, ....
Make up some samples of the problems, call the dealer and arrange to take it back to show them the results and either have it adjusted, or show you what needs to be set where to achieve the results you need...........it is under warantee, and you should expect it to function correctly.
I would not advise you fiddle with anything other than tensions and stitch selector on such a new machine.
Ask if you can have a 15min familiarisation lesson on the machine........we actually offer 3 x 30min free lessons on the use of a new machine so our customers can get the maximum benefit from their purchase.
It has proven to be a good business decision, as we get fewer frustrated phone calls and folks actually go and use the machines properly from day one.
www.bargainbox.com.au
Posted on May 31, 2008
My brother innovis machine has a problem. Top thread frays and breaks, not not seem to be picking up bobbin thread properly. I have changed the needle tried a previous bobbin.
Be sure to install a brand new needle--check that the needle eye is the correct size for the thread you are using--a small needle eye will shred heavy thread. It may also help to remove the top thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Try different thread--AVOID old or bargain bin thread. Check that the upper tension is not too tight.
If the top does not pick up the bobbin thread, the machine may be out of time.
Otherwise, there may be a burr or snag somewhere along the thread path that is catching and fraying the thread. Sometimes there is a snag in the bobbin area (possibly the needle plate or hook) that is rubbing the thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
What Causes My Thread to Shred
Fraying Breaking Madeira
Nov 09, 2017 | Brother Sewing Machines
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
Aug 19, 2016 | Sewing Machines
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
Upper cotton not picking up bobbin cotton
Most likely a timing issue. the needle hook and needle are not aligned correctly.
Jan 30, 2015 | Brother Sewing Machines
I cant get upper thread to pick up bobbin thread
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out Good luck!
Oct 18, 2013 | Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
I am using my new brother CS-60001 sewing machine for the first time and I can't stop the bobbin thread from tangling. I feel the machine is threaded correctly, the bobbin thread is tightly wound and...
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
Sep 06, 2011 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
232 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
