Question about HP Pavilion Media Center TV Desktop with AMD Phenom Processor 9500
Games work slow
Hi i found the name of the motherboard
M2N68-LA
and it says asus somewhere
  • Thnygaard May 31, 2008
    CT:P 9990 28 02 VJ 20V
    PN 5189 1661 REV: FO1
    HP PIN 5189 1661 CB1R551 00506
    atleast these numbers where on the motherboard dont know wich one you needed so here you have all of em
    Problem Solver:
  • 13 Answers
Hi, You said ALL your games are choppy ....Conan is a demanding game ..
Example:
I have seen it run on a MSI board with 2 Gs of PC6400 (800mhz) / AM2 4800 X2 (2.5Ghz) with an AGP!!! GS7800 Nvidea video card (which was a good card in its day...42Ghz bandwidth) ...it ran at about 30fps on Medium settings which is livable???...
The first thing to do is to make sure you have all the latest drivers for your Motherboard from HP (made by Asus for HP )
also make sure Windows OS it self is all up to date ....
The video card is 8800 Nvidea ? which one?
Go to the Nvidea and get the lastest drivers for it ...this is MOST IMPORTANT ...
You also have onboard Graphics card 6150 ...go to Device Manager and see what is listed....To access Device Manger Go to ....Start>Control panel > Systems ( maintenance) and select Device Manager....click the + sign next to Display adapters and if the (6150 onboard graphics adapter) is listed with the 8800 right click on the "6150 " choose Properties and make sure it says..... ( do not use (disable) under .".Device usage."....
....Apparently these can run concurrently
HP says PC6400 Ram (800 mhz) will run on this board.....a PRICEY option of course
NOTE: All RAM isn't created equal it is best to use a Quality RAM from the SAME manufacturer //try not to mix n match
Lastly there's the Power Supply ...the new Video card will draw more power ....a good 500 plus watt PS with good Amps well
across the Voltage rails 3/5/12 .....25A plus is a good target
Again more money :)
Also turn OFF Programs while gaming I do no matter how fast the Rig is .... ie Antivirus...etc..... every little bit helps
Do the Driver updates and see what happens ...Good Luck
Posted on May 31, 2008
Motherboard cd
Hi. Most motherboard CD's are lost, and this is nothing to fret about. You can find most of the drivers and downloads, and even the manual at the M2N68 page at ASUS' support.
(http://www.asus.com/Motherboards/M2N68/#support_Download)
Dec 17, 2013 | ASUS M2N68-LA Motherboard
M2N68-LA motherboard 12vdc for the cpu fan is only 4vDC.
first change u r smps if no diffrence problem is same then disconnect all chassis fan one by one and check voltage again.
Feb 05, 2013 | ASUS M2N68-LA Motherboard
How can make my sound work on my m2n68-68?
You need to go to the Asus factory support site, all the drivers are there by application ans the part number of the board.
Jul 03, 2012 | ASUS M2N68-LA Motherboard
M2N68-LA (NARRA3-GL8E) Motherboard Manual - ASUS Owners User Manual
There has been a lot of confusion going on around the net. However I find the driver which should work just fine with your model. However the driver is from HP/COMPAQ and the model is M2N68-LA (Ivy8)
You can download the drivers from this link
Documentations will be available here
If you have doubts let me know.
Nov 04, 2011 | ASUS M2N68-AM SE2 Motherboard
Hi.I have a ASUS M2N68-AM SE2 Motherboard with AMD Athlon 64 X2 6000+ Processor.Whenever I boot,it says that the CPU is not supported.I have updated my BIOS to the latest version.Still doesn't help...The...
What bios are you using? Usually that error message can be disregarded since you can manually set the CPU clock, voltage, etc in the bios and it should work. Also, this might mean that the bios currently loaded is corrupted/broke. But since you did update the bios, to what version?
Also, are you using the integrated graphics for gaming? If so, that would not suffice for heavy gaming at high resolution. You should be using a dedicated video card for that.
As for system performance, how slow is it? What is your OS as well? can you try to download cpuid, and see if your processor is detected properly in windows.
Apr 27, 2011 | ASUS M2N68-AM SE2 Motherboard
I need sound driver asus m2n68-am se2
Hi, my name is Babak, I'm here to help you.
Use this link to find drivers for your motherboard. make sure you select right operation system in "Operation System" menu.
http://support.asus.com.tw/download/download.aspx?product=1&model=M2N68-AM%20SE2
Keep in touch with me. Babak
Feb 15, 2011 | ASUS M2N68-AM SE2 Motherboard
HP Pavilion Media Center TV Desktop with AMD Phenom Processor 9500 Logo
207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
