Question about HP PSC 2355 All-In-One InkJet Printer
Coping problem HP psc 2355
When i copy something it cuts off a piece towards the end of the original. i have been playing with the setting maybe i could find the problem but no luck. the scanner works fine and when i print from my pc no problems.
  • 27 Answers
It seems to a hardware issue with the scanner
It needs to be replaced
Posted on Jun 02, 2008
Frozen blue screen
have check it to the service center maybe some wire got loose or cut
Aug 08, 2011 | HP PSC 2355 All-In-One InkJet Printer
My hp psc 2355 keeps on sayin CARRIAGE JAM
Hey
I gues this video in youtube sloves your problem
please let me if you face further problems
Thanks Anil
Jun 14, 2010 | HP PSC 2355 All-In-One InkJet Printer
PSC 2355 All-In-One InkJet Printer: MY HP PSC 2355 printer is printing slow...
Please perform the steps below and check
1. Right click on My Computer and go down to Properties.
My Computer is usually on your desktop or in the Windows Start menu. Click on the Advanced tab at the top of the screen.
2. Under the Performance section, click on Settings.
3. Click on the Advanced tab.
4. Under Processor scheduling click on Background Services. Click on Ok then Ok again.
If the issue still persists please get back to me with the Operating System of the computer
May 18, 2010 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
Run as error on dell
go to control pane/ user accounts/ user accounts/ look at your acct (make sure its says admin and not limited) if limited change it to admin. reinstall software, you should be on way now.
good luck
Jun 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
Either will not turn on or shut off without giving error mess.
I have Hp PSC 2355 printer, and will not turn on. power supply is ok, and transfomer is workingHelp thanks
Mar 23, 2009 | HP PSC 2355 All-In-One InkJet Printer
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
I get an error messege (carrige jam)
I have found that when I slide back the carriage to the left by hand and expose the bottom right hand side, there has been an accumulation of ink that is preventing a part from sliding from front to back. Inspect the bottom right hand side where the black and color cartridges normally sit. You will find a flat sliding piece directly beneath the position where the cartridges normally sit, that will not slide forward to the front of the printer and back towards the back of the printer easily because of the ink that has accumulated and is causing a drag. I used q-tip swabs and some alcohol and cleaned out the rails that the piece slides in. Use a flashlight to inspect. After cleaning it appears that it is printing normally again. Repeat the process as needed. Bob in NC
Jan 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sep 21, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
