Question about Craftsman Garden
I have a Craftsman 917.275670 I changed out battery and fuse. and started right up. Now when I pull the blade engage knob, the engine dies and fuse blows. I replace the fuse and try again, same problem. Any ideas?
  • 79 Answers
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Posted on Apr 08, 2009
  • 62 Answers
SOURCE: FUSE BLOWS WHEN BLADES ARE ENGAGED CRAFTSMAN MODEL # 917.27686
Most probably you have a wire shorting to the frame of your mower.
Trace (follow) the wires from the switch, checking for any frayed, burned, or bare wires.
Repair as needed.
Posted on Apr 17, 2009
  • 11 Answers
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Posted on Jun 24, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
SOURCE: the blades on my craftsman 22hpohv gt5000 won't
I would check to make sure that the pullys are free. With it off reach under and see if both or more blades turn freely. If the bearing is frozen it would cause this problem.
Posted on Jul 02, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Does model # 917.276021 have a mower lock out on the transmission
The PTO when engaged draws a lot of power from the battery. Check the battery for proper voltage. If your battery is low or say 1/2 charge, it will never engage the blades and will die every time you try to engage the blades.
Aug 04, 2014 | Craftsman Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Belt. came off... pulling up blade engagement knob nothing seems to happen.....I have trackter up on blocks with blade cutting height at 1 with engine runnig the blade engagement knob switch ...
sounds like a bad PTO, that is the electrical gizmo on the bottom of the engine's driveshaft which engages the bottom pulley, running the deck. you might luck out and find the fuse is blown so follow the wire from the PTO back until you find the fat part in the wire. the fat part is an in line fuse holder with a fuse in it. if the fuse is bad and blows again, you need a new PTO
Aug 19, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The blades on my craftsman 22hpohv gt5000 won't
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
Jun 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman zts 7500 zero turning radius 26 hp with a pull knob over elec.To turn on the blades.It also has an elec.raised deck.When I pull the knob to turn on the blades the engine dies.And when I...
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hi
Apr 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
