Question about IMSI FormTool Express (804526016497)
I have run Formtool DOS for nearly 20 years. I need that first version for windows that converts DOS files, [ I have a thousand of them ] to windows compatible. I have about 5 versions of Windows Formtool but none of them will convert DOS files. DAMN. Easily worth $ 100.00 to me to get that converter.
3 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: I have an old version of your clip art product.
Are you sure it won't work, outright?
Try installing it. If it doesn't work you can try installing via Win 7 compatibility mode.
Let me know if you need specifics.
Posted on Dec 06, 2009
SOURCE: does Hijaak Pro version 5 run on Windows 7 64-bit?
Share with you a good site that you can get cheap ************ from there: www.vanskeys.com, all versions of windows keys and office keys can be found in that site.
Posted on Aug 17, 2016
I have Outlook latest version on my Mac. How can I convert olm contacts to pst format?
You can use the tool OLM to PST Converter Ultimate to convert Mac Outlook OLM to PST. The tool supports all versions of Mac Outlook including the latest version. When you install the tool on your Mac, it is an easy process to move it to Windows Outlook.
You can convert Mac Outlook to Windows Outlook using express mode of this tool in a very easy and professional way. There is no issue in moving from Mac Outlook to Windows Outlook with this tool. When the OLM files get converted to PST, they become compatible with Windows Outlook. These files will support your latest Outlook version.
The Autoload is an advanced technique by which the tool fetches your email data from Outlook identity folder and exports it to PST file. Apart from that the calendar and contacts are also exported to PST files. The data export feature of this tool has a setting to limit the size of PST files.
The data integrity has a very high importance, and the output data is compatible with Windows Outlook file format. The tool has an evaluation copy for users to download and test, which is same as the licenced copy with a difference of limited conversion. You can try it now! http://www.gladwevsoftware.com/olm-to-pst-converter-pro/
Aug 02, 2017 | The Computers & Internet
It is possible get for hawei broadband e173 windows 98 driver files?
Nearly all USB modems have storage with a setup and drivers. The box it came with would state what operating system it is compatible with. If Windows 98 is not listed, it does not exist.
Development on the Windows 98 platform has stopped world wide because it is a version of DOS (unsafe, drive space and memory limitations) and no longer supported by Microsoft. Todays software configurations are saved in the registry, Windows 98 and DOS are located in various INI type files.
My suggestion? Run Windows 7 and download the free Microsoft Virtual PC package, install Windows 98 in a VM and it can use the internet shared by the host Windows 7 system.
Sep 12, 2011 | Computers & Internet
I use Paradox Version 4.5 on my old Windows XP computer. Now I need a new computer that will have Windows 7. How do I install my Paradox 4.5. I've all ready tried everything that I can think of but no...
I use "DOS Box 0.74". it opens a dos window that you can run paradox in. Its FREE and works great, even in full window mode. Only issue I had was I toggle to DOS occasionally to clean up txt files and DOS Box has limited DOS commands.
Jul 26, 2011 | Borland Paradox 4.5 Full Version for PC
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
The picture dos not open i need program
Use the supplied Sansa Media Converter program to convert and transfer your pictures (and videos). If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
Mar 07, 2011 | SanDisk Sansa e250 MP3 Player
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
I need to know if I need a patch to run DOS applications.
Legacy DOS no such luck either you have corrupted files or a buggy version of program ie DOS 4 was buggy and Netscape 4.7 was also buggy . Advoid Windows 9x O/S 95 had the blue screen of death thats why I use over 2K O/S
Apr 16, 2009 | Computers & Internet
Microsoft works 7.0
From the Microsoft Office 2003 Web site:
Excel 2000 or later versions cannot directly open files created in Microsoft Works version 3.0 or later. To open a Works file in Excel, first open it in Works and use the Save As command to convert it to one of the file formats listed below. Then close the Works file and open the converted version in Excel.
  • Works for Windows 2.0/Works for DOS SS
  • Excel SS
  • Lotus 1-2-3
To open a Microsoft Works database file in Excel, first save the file in Microsoft Works as a dBASE file, and then open the dBASE file in Excel.
Feb 11, 2008 | Computers & Internet
MS-Dos running
give this a run...
put the file in your base drive (in C:/)
Start>Run> "c:">*insertfilename WITH ".BAT" at the end*
It will either work or just fail and leave the window open with whatever was displayed on the screen(hopefully, unless the bat has a "close window" command in the end of the file)
Jan 31, 2008 | Computers & Internet
IMSI FormTool Express (804526016497) Logo
217 people viewed this question
Top IMSI Computers & Internet Experts
Hardware and...
Braden Bills
Braden Bills
Level 1 Expert
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
