Question about GE Dishwashers
Motor hums, but won't start - GE Dishwashers
    Sergeant:
    Champion:
  • 351 Answers
Hi may have something in pump or if it has been sitting for awhile the pump maybe stuck. jim
Posted on Oct 11, 2010
GE Dryer GFDN110ELWW hums loudly and won't start
The start capacitor is built into the motor and you will need to replace the motor. Here is the motor if you should need it.
Nov 24, 2012 | GE GFDN110ELWW Electric Dryer
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
My dryer was in the rain and now won't work...just hums
If the motor just hums and it will not rotate the drum, you will need to replace the motor. Here is the motor to order.
Nov 18, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Motor hums but won't start
Most problems with humming motors are with the power input TO the motor (Not enough power to turn the motor)
I'm guessing it is a single phase compressor? If you have it connected to an extension lead, then, if you can, try plugging it directly into the wall, (you can lose vital power through the long lead itself) Second the capacitor attached to the motor could be on its way out or shot. You would need to get it tested, or if you notice anything bulging out of it, then you know it needs replacing. If all the above are ok, then you would need to get the motor itself checked out by an electrician, the bushes or coils are probably gone
Hope that helps
Sep 10, 2012 | Air Tools & Compressors
Dryer motor hums ant wont start
Thais probably the motor but it might be something in the blower housing. Their are lots of movies on youtube that will show you how to do it. Now here is my home movie of a dryer like yours:
Sep 08, 2012 | KitchenAid Dryers
Band saw motor won't start just hums
You will need to take the motor out and check the brushes on the back also check the bearings you may need to disassemble the motor to repair.
Apr 05, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Amana front load washer hums only
A centrifugal switch to allow the motor to start up on the start winding and once started it opens to take it out of the start winding. The motor has to have voltage applied to the start winding and the run winding at the same time in order for the motor to start. The capacitor is part of the start circuit. When the motor goes to start, the voltage must be applied to the start winding in order for the motor to start or it will just hum. The moment the motor reaches a certain RPM the centrifugal switch opens up to remove the start voltage to the motor and it will remain running on the run winding. The motor will not start up on run voltage alone. It needs both, the start voltage and run voltage.
I think the problem is that the motor is not getting the start voltage supplied to the motor or the start winding has opened up in the motor.
Oct 22, 2011 | Amana NFW7300WW Washer
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Dishwashers Logo
184 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
