Please revisit "toshiba 1410. wont turn on" - Computers & Internet
  • 133 Answers
You could be facing several problems, first make sure u'r plugs are ok, the charger is ok, the power button is working ok, the battery is ok, if all this things are ok then you need to open and check the motherboard especially the area near the power jack and check for loose points in the soldered areas.
Posted on May 31, 2008
Toshiba 1410 cooling fan replacement
Contact a Toshiba repair center in your area, Alternatively a computer technician will do.
DIY install, components may be found on Gumtree or e-Bay.
Take care!
damnor01
Apr 28, 2012 | Toshiba Satellite 1410-S173 Notebook
How to change RTC battery of Toshiba Satellite 1410
RTC battery is located underneath the palmrest - to the left of the touchpad - they don't usually die, as they are Lion rechargeables. Unless your Satellite 1410 is losing date and time every time it is turned off, you probably don't need to replace it. But if you need to replace it, make darn sure that you replace it with a rechargeable and nothing else.
If you need to get to it, you'll need to remove the keyboard, then the square aluminum bracket above the heatsink, then get to the bottom, remove all the F6 and F26 screws, then you must make sure to disconnect the WiFi antennas. After that, the top case (including the palmrest) will unsnap from the bottom case and you'll be able to see the RTC battery.
Aug 30, 2011 | Toshiba Satellite 1410-S173 Notebook
My monitor wont turn on it plugged in and every thing
my 1410 toshiba wont turnon the ac light and battery light turn on but laptop will not turn on.. any help. please
Aug 20, 2010 | Dell Dimension 4500 PC Desktop
I need to use recovery disc on my laptop 1410/2410 Toshiba
Power down the notebook, as soon as you power it up continually keep tapping on the 0 (zero) key. You should see "Hard disk drive recovery mode"
The "recovery mode" will bring your notebook back to factory default settings so please save your data because you will lose it.
In case Toshiba changed the older models,(which seems to be the case) here is a link to a pdf file from Toshiba
http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
Hope this helps.
Nov 10, 2009 | Toshiba P000355040 - Satellite 1410 and...
HP PSC 1410
You MUST obtain the VISTA version of that CD (if it isnt a vista driver CD) or you may go to the HP website and download a VISTA driver from there
Jul 06, 2009 | HP PSC 1410 All-In-One InkJet Printer
How to manual on replacement of cmos batter in Toshiba 1410-S173
cmos battery is present inside the motherboard...go to tosibha website and enter ur model no...der u can download the hardware mannual for the particular model
Jul 04, 2009 | Toshiba Satellite 1410-S173 Notebook
Wirless radio switch for Toshiba 1410 S173
If it ain't the WiFi Antenna on switch (right side, towards the front), then it's an incompatible WiFi card (assuming it's just been added to the system).
Nov 26, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba 1410. Won't turn on
Sounds like a dead battery, You need to try it with an alternative battery, most laptops won't aeven switch of if the battery is damaged, also try ro pull out the motherboard and find for dry joints. i.e. any lose transistor or capacito and try to re-solder it, the put the laptop back together,
Feb 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
